420W rockshaft seals
jeff spencer
12-02-2006 07:00:10
I have just replaced all the seals in my dual "TOM". My question is how do you line up the shaft from the quadrant into the arm inside. I cant find any markings and it is not master splined. i dont want to re-install wrong and have to pull it all back apart. hope you guys can help.
Wayne in Tn.
12-02-2006 09:53:11
 Re: 420W rockshaft seals in reply to jeff spencer, 12-02-2006 07:00:10
Jeff, on the rear one, there is a roll pin that goes through it. So no problem there. The front one can be installed at any position, then expierment with spline locations by moving the quadrant lever all the way up and all the way down until you achieve full travel on the lever. By moving its position on the outer splines on the shaft.
jeff spencer
12-03-2006 07:16:44
 Re: 420W rockshaft seals in reply to Wayne in Tn., 12-02-2006 09:53:11
Thanks for the information Wayne. I got it back together yesterday and had to move it 2 splines to get full travel. your info was very helpful.
Wayne in Tn.
12-03-2006 10:31:18
 Re: 420W rockshaft seals in reply to jeff spencer, 12-03-2006 07:16:44
Great! Glad you got her back together>>>>
