1946 JD A Starting
LDP
11-30-2006 18:07:52
I just bought a 1946 JD A with electric start and slant dash. One compression petcock leaks and the other is broken. Should these be replaced or could I just remove them and replace with some type of plug? I don"t know if they should be opened to make it easy on the starter or if they are needed for any other reason? Thanks!
DW
11-30-2006 22:13:24
 Re: 1946 JD A Starting in reply to LDP, 11-30-2006 18:07:52
You may decide not to replace them with original equipment from "Mother Deere" when you price them. I priced them recently at my local dealer, and found them to be around $38 each. There is however no subsitute for original. My 2 cents worth.
Pappy
11-30-2006 21:46:22
We have a "46 "A" which is 6 volt. I never open the petcocks and it starts instantly with no problem.
John T
11-30-2006 18:27:34
LDP, Theyre used more on the hand start tractors so the flywheel is easier to roll over, on electric starters I pretty much just kept them closed n never messed with em, however, it would indeed be easier on the starter if one wished to use them and especially if you had an older A that was only 6 volt. No reason why you couldnt just replace them with a plug if youre not gonna use them n dont wanna fix the leaks.
John T
gtx 1967jewison
12-01-2006 09:04:53
 Re: 1946 JD A Starting in reply to John T, 11-30-2006 18:27:34
i would strongly recommend fixing it with good ones, just a little thought of fact that a spark plug fires better under less pressure so leaving them open for a few seconds after it starts helps keep plugs clean, unfouled. once the mist/ smoke etc goes away & it's burning clean/hot you close them. helps also if troubleshooting ignition or carb problems, oil burning problems, etc. cold weather also another time they help greatly. if you accidentally flood the engine they help alot to clear the excess fuel. just my 2 cents.
