730 thermostat
Ferd
11-30-2006 08:03:34
My 730 diesel won't come off the cold peg unless it's worked hard. Is this typical? My I&T manual says the thermostat is located in a housing by the head, but a friend's manual indicates it's in a housing between the upper pipe and radiator. Where is it and how difficult is it to get at?
Ferd
12-01-2006 08:15:44
 Re: 730 thermostat in reply to Ferd, 11-30-2006 08:03:34
Thanks for the good information! I'm thinking this might also be the cause of it wet stacking.
WeirdDeere
11-30-2006 23:47:40
My 70D never got much above 140 degrees when putting around, I opened it up and found that the thermostat was gone like many have noticed. Put one in, and it gets to 180 just putting on a warm day. Just putting around on a cold day it still gets to 160 or so. Working it of course will make it stay at 180 or more.
Your 730 is probably exactly like my 70, the thermostat is at the bottom of the upper water pipe. I found it easier to unbolt the water manifold and move it back, put in the thermostat, and bolt back together.
It's better for the tractor, and not too much work to install a thermostat. Deere still has 'em for a reasonable price.
Brandon
My Industrial John Deere website
John Deere Diesels
The LaGrange Engine Club
Geoff Mathews
11-30-2006 12:55:36
My 730D has never had a thermostat all the time that I have owned it. A few years ago it started running warm - then I had to replace the radiator core as it began to leak. Now once again the temp needle nevers lifts off the peg no matter how hard I work the tractor.
buickanddeere
11-30-2006 19:49:04
 Re: 730 thermostat in reply to Geoff Mathews, 11-30-2006 12:55:36
Too cold. They have to run 180F min and 195F is best. Colder than 180F and they waste fuel and suffer increased cylinder wall wear.
GPULLER
11-30-2006 08:31:21
The diesels do take a bit to warm up but it should come up to temp with even a light load. My 720d runs up to 180 while working and will get up to 160 just idling.
The thermostat is located in a housing at the top tank of radiator. To get to it you'll have to remove the hood, the upper water pipe, unbolt the lower part of the thermostat housing and change out the thermostat. Thermostat is still available from Deere, I think it's the same one used in a 4010 or 20.
