4000 vs 4020
PeterE
11-30-2006 07:23:15
Anyone have first-hand experience on the JD 4000? From what I've read, they're a 4010 with a 4020 engine. My father, however, was reading the parts book and says they're identical (of course, the 4000 usually shipped with fewer options). The data books all show the 4000 to be about 1,000 pounds lighter. Extra remotes and a radio can't account for that much weight.
Stan - Florida
11-30-2006 17:05:23
 Re: 4000 vs 4020 in reply to PeterE, 11-30-2006 07:23:15
I've read that the 4000 was built as a replacment for a 3010/3020. It did have a 4020 engine, I think, and was built to enable famers to move up in power and speed, pulling the same implements they had been using on their 3010/3020 tractor in at least one gear higher. Cover more ground with the same implements and save on equipment cost was the theory. It was built as a "runner", not as a "lugger".
Stan
buickanddeere
11-30-2006 19:52:04
 Re: 4000 vs 4020 in reply to Stan - Florida, 11-30-2006 17:05:23
Just 99% of a 4020 built with fewer options. Not a 3020 with a 4020 engine.
Stan - Florida
12-01-2006 12:37:51
 Re: 4000 vs 4020 in reply to buickanddeere, 11-30-2006 19:52:04
You're absolutely right. I went back and found the article from August 1996 and re-read it.
I didn't intend to imply in my first resonse that it was a 3020 with a 4020 engine, only that it was intended to fit in between the two models.
Thanks for the info.
Stan
low budget
11-30-2006 18:01:04
Maybe not to replace the 3020 as much as to fill the 20 hp gap between the 3020 and 4020. Also to provide a cheaper alternative to the 4020 to compete with tractors like the IH 756 and Allis 190xt. Your right about how JD "sold" the concept to buyers.
ET
11-30-2006 09:49:34
The 4000 just had a frame to hold the batteries instead of the battery box. There is no syncronizer on reverse in a 4000.
Mike M
11-30-2006 07:45:17
I was also thinking no sheetmetal around the seat area and only 2 headlamp bulbs instead of 4.
You might even have to pay more for one today given that I think these newer tractors are getting to be todays collectables and that was a rarer model.
JD Jim
11-30-2006 07:36:18
This topic always gets a lot of responses. The only significant difference between the two is the 4000 uses 3 1/8 axles and the 4020 uses 3 3/8. The lack of a front pto on a 4000 is also important though very few people ever use it. Otherwise they are virtually identical other than options. There were very few 4000 made compared to 4020 and they only came as side console. You cant go wrong with a good 4000 as it will be cheaper than a 4020 and will do the same job.
PeterE
11-30-2006 11:35:41
 Re: 4000 vs 4020 in reply to JD Jim, 11-30-2006 07:36:18
Thanks for the reply. So the 4000 uses a lighter axle? Did the 4010 also use the 3 1/8 axle?
WTW
11-30-2006 14:09:35
 Re: 4000 vs 4020 in reply to PeterE, 11-30-2006 11:35:41
The 4010 did use a 3.125" axle but not the same axle as the 4000 tractor axle. The 4000 final drive housing and axle shaft were unique parts to the 4000 tractor only. Planetary ring-gear, planet gears and sun gear are the very same parts as the late 4020 used. The planet carrier in the rear final drive was also a unique part to the 4000 tractor due to the odd axle shaft spline it used. All these unique parts for the 4000 are no longer available. The good news is if you ever needed them 4020 final drives will bolt right up. A 4000 was a lesser opted late model 4020. Very good tractors in there day! DW
msb
11-30-2006 17:02:28
 Re: 4000 vs 4020 in reply to WTW, 11-30-2006 14:09:35
All this only to save the farmer $600 on the purchase cost.That was why Deere didn't sell all that many 4000 models.They were a very nice tractor however except for being equipped with that CB model injection pump, but the 4020 also came with it too.
JD Jim
11-30-2006 11:46:31
I dont know which axle was used in the 4010, but most opinions are that the 4000-4020 was a huge improvement over the very popular 4010. No comparison really.
