1942 A
frank van den d
11-30-2006 03:59:27
can the later con.rods#a4648r be used in a 42A? thanks.
Toot
11-30-2006 11:36:55
 Re: 1942 A in reply to frank van den dorpel, 11-30-2006 03:59:27
Yes they will. Journal size is same.
Mike M
11-30-2006 04:40:16
I'm not sure which one an A4648R was out of ?
But I'm 99.9% sure all A rods from 1941 and up are the same and you can even use the insert ones from a model 60.
11-30-2006 05:04:44
 Re: 1942 A in reply to Mike M, 11-30-2006 04:40:16
hi mike.app.they are insert type out of a 48A.
Mike M
11-30-2006 06:38:20
 Re: 1942 A in reply to frank van den dorpel, 11-30-2006 05:04:44
If you happen to have a parts book handy clear at the end of the list of parts on the rod page you should come accross the listing for the insert rods and casting numbers and insert numbers too. I'm sure they will fit as the old babbit ones subbed up to those for the 60
