3020 bad motor
Highwired
11-29-2006 23:31:25
Hello, My dad has a 3020 diesel with a bad motor. The rod was pushed out the side of the block. I thought I would look around for a used John Deere combine with a good motor. I would not have any problem with a gas motor. Dad is retired so it would not get used everyday. Does anybody know what model combine I should look for. Thank you and have a great day.
teddy52food
12-01-2006 11:09:12
 Re: 3020 bad motor in reply to Highwired, 11-29-2006 23:31:25
Sometimes a hole in the block can be welded shut if it doesn"t involve the water jacket. Why did it throw a rod? Is the crank shot? I would get it apart & check it out before doing anything else. Years ago I had a 440 chrysler that broke a rod in the middle. That piston stayed up out of the way, but the rod broke the camshaft and put a hole out both sides of the block. After getting the engine completely stripped, I cut pieces to fit the holes & welded them shut with nickle rod. Reassembled useing new parts as needed. I drove it over 80,000 miles after that with no problem.
buickanddeere
11-30-2006 19:55:49
About the only option is to scrap the tractor. Or spend more than it's worth finding 4030/2510/2520 parts to swap in a four cylinder Dubuque engine. A Kinze engine swap to a Detroit or something is almost a legitimate alternative.
Arthur Driesse
11-30-2006 18:58:41
Fix it,3020 diesel engines arehard to come by and if you find one you'll pay dearly.
adsma
11-30-2006 13:34:16
Your best bet, and it won't be cheap will be a find a block from a salvaged 3020. Get the casting number off the block and start making some phone calls to salvage yards and have them look on the locator if anyone has a good used block. Like I said it won't be cheap, but it is the only solutuion besides trying to find a complete motor.
msb
11-30-2006 06:54:37
3020 engines are very hard to find since they were only used in tractors.Your best bet might be to have your block repaired.
Troy Ri
11-30-2006 06:25:04
I Don"t Think they used the 3020 diesel engine in the combine .
jdemaris
11-30-2006 05:22:54
I don't know much about the combines, but the industrial Deere 500A uses the same engine as the 3020.
Mike M
11-30-2006 04:37:15
I don't think they used that engine in anything else.
