1944 B pistonscarb.
I B Mark
11-29-2006 20:06:08
will late style B pistons work in early styled
if bored to fit? it has dltx10 will other B carbs work aswell?
Toot
11-30-2006 11:41:16
 Re: 1944 B pistonscarb. in reply to I B Mark, 11-29-2006 20:06:08
yeah they can be bored, done this a lot (4 1/2" to 4 11/16") Dltx 10, 34, 67 are B carbs all will work, the A carbs will even work, but you really have to play with needle settings.
Mike M
11-30-2006 04:52:10
I have heard alot of people have done just that over the years and it worked as long as you are a 1941 and up with the 4 1/2" bore. Of course there's always a chance of hitting a thin spot in the block. Any carb. made for a B should work. An A carb. tends to run too rich and foul out plugs. You could also swap out the camshaft for a later B one also as they have more lift.
