420 crawler starter
Larry Hardesty
11-29-2006 16:04:58
I had to be out of town for a couple of months. Went to start my John Deere 420 crawler yesterday and it would not start. I pulled the starter lever and nothing. The battery is up. Any common things I should look for. It may be as simple as some corrison somewhere but I thought I would check with the list and see if there is some common problem with the 420 starter. Thanks in advance.
Hayfarmer
11-29-2006 18:29:09
 Re: 420 crawler starter in reply to Larry Hardesty, 11-29-2006 16:04:58
check the easy things first. Battery connections. Even if they look good there may be a film between cable and post. If that doesn't work, loosen the starter and jiggle it, maybe stuck in flywheel. See if starter will spin off of tractor. I worked on one of these once where the engine froze up. Is there any sound from starter, click etc? will bet on corroded cables.
Larry Hardesty
11-30-2006 09:42:47
 Re: 420 crawler starter in reply to Hayfarmer, 11-29-2006 18:29:09
Thanks, I will start with corrosion. I put a battery charger on it and it seemed to draw down on the juice but no sound from the starter..not even a whir, which makes me think something other than just correded cables. Nevertheless, that usually is the case and that is where I will start. The battery is under the gas tank and not easy to get in and out. Thanks. Larry
