Model A flywheel gets loose
cammerkit.
11-29-2006 16:03:55
I'm posting this for a friend, hope you can help. He has a model A and after about 6 hours of run time the flywheel gets loose. Says it sounds like the motor's gonna fly apart. The counterweights on the clutch disc and flywheel are 180 degrees apart as he believes they should be, but he is stumped. What should he check? Thanks for any advice. Gary
Hig 5060
11-29-2006 19:08:39
 Re: Model A flywheel gets loose in reply to cammerkit., 11-29-2006 16:03:55
I put metal lox on my B about 1 year ago and it hasn't moved since. Its about like JB weld or something. You probally would have to pull it off with some sort of puller but its not like you need to pull it very often. Maybe a temporary fix but it works.
Duane Larson
11-29-2006 17:48:19
Gary,
Assuming he is tightening the bolts "tight", he may have stretched the bolts beyond their limit. The solution is to replace them (I think Correct Connection has the proper square headed grade bolt). If the crank splines are worn, or the flywheel splines are worn, there is no good solution with his present crank/flywheel. He does have the flywheel/clutch disc properly set up.
One good option is to replace his flywheel with a taper loc flywheel. They are designed to snug up on worn cranks. A search of the archives on this site for taper-loc will turn up the phone number of the company in East Tennessee that makes them - cheapest to order directly from them.
cammerkit
11-29-2006 18:18:23
 Anybody have the phone # to Correct Connection? in reply to Duane Larson, 11-29-2006 17:48:19
Thanks for your response. We'll check the bolts this weekend. If anybody has the number to this tractor hardware company I would greatly appreciate it. Gary
Duane Larson
11-29-2006 18:38:17
 Re: Anybody have the phone # to Correct Connection in reply to cammerkit, 11-29-2006 18:18:23
A search of the archives gives: Correct Connection, Rockwod , Pa. Phone 814-926-2777 e-mail [email protected]
