Early A Oil Pump
Mixman
11-29-2006 15:43:22
I am working on a early unstyled A pre#424024 with no oil preasure. We have cleaned the line and the riser. I only have the parts book on this so my information is limited. No pictures. Can any one help me maybe walk me thru this. Thanks!
Earl-IL
11-30-2006 08:28:55
 Re: Early A Oil Pump in reply to Mixman, 11-29-2006 15:43:22
Everyone is correct. The pumps in the side lose prime.If I recall my 1935 "A" did it years ago when it set a long time =6 mo. I took a 1/8 pipe plug out of the governor housing and pumped it full of 30 weight oil and turned the flywheel backwards and it primed the pump. My tractor is at a diff. location now I will have to go look & see exactly where the plug is. I use 15-40 in it now and it hasn't done since ,but I always check when I fire it up. I think the GP has the same problem. If you take it down the pump is rebuildable. I saw a set of new gears on Ebay last week .I think they brought $85-$90. Earl
almrm
11-30-2006 06:19:30
I have a similar A (417034) that had the same problem shortly after I got it. I took it back to the company that sold it to me which also has a big JD salvage yard. I worked with the owner and mechanic to slove the problem. Both are very good with JD 2 cylinders.
With my pump and a salvage pump side by side, this is what we found:
Slits to allow the oil flow between the gears and the cover had some build up which was cleared.
The plunger was pitted bad on mine and some on salvage pump. Polished and used the best plunger.
Spring behind the plunger was very weak on mine compared to the salvage unit. Used the stronger spring.
Like the gears, there is no gasket available either. We made the gasket from THIN stock taking care that the tapped out gasket had no imperfections. (took two tries)
Disassembly and reassembly is tight behind the flywheel, but can be done. We chose not to remove the flywheel.
There have been no further problems. My oil pressure pin indicator pops up immediately in all weather, engine temp, and engine speed conditions. No overfilling necessary.
We felt the weak spring and plunger condition was likely the problem.
I agree with others that the newer pumps are a much better design.
Good Luck,
Mark
Mike M
11-30-2006 04:59:16
That was a bad design I guess that's why they changed it. Those gears can wear out bad and I think Greg Stephen may also have reproductions. If your gears are good then you may need to overfill the oil.
greenmech
11-29-2006 20:42:51
Detwilers in Wis sells repro pump gears if your are worn out. 715-659-4252. Part #A1064. Ron Mn
George S. in the real NY
11-29-2006 19:01:31
I got an A like yours. The pump is driven off the gear on the crankshaft and as another post says it is up on the inside of the crankcase. It is NOT driven by a shaft with the coupler on it. Mine had the gears so hopelessly worn that it would not prime. The short soultion was to add more oil. I even made a dipstick and drilled a hole under the breather filter to stick the stick thru to know how much oil was in the sump, cause now the level is way above the test cock. The piston had to be near top dead center but it did give indication of oil level. The gears have been obsolete for some years. About 10 years ago, I took the pump gears out before winter, brazed the teeth, and one cold winters nite sat down with some beverages, some new flat files and made new teeth on the gears. Took some time but it can sit for a year or more and it pickes up prime and get pressure by the time the choke is off. Yeah, kinda crude but with time and checking the fit and clearance as the gears rotated, it was fixed. HTH George S.
Ron B in Co
11-29-2006 18:03:07
I have a 1935 A that would lose oil pressure when the tractor was run on unlevel ground with the oil pump on the high side. Also was difficult to get oil pressure after sitting for a long time. I finally just decided to run about 4 extra quarts of oil in the crankcase cause I don't use it that often. No problems with oil pressure with the extra oil.
430WLPG
11-29-2006 17:56:27
I agree with Maark they do need primed. Those Early A's have the oil pump in the side of the main case behind the flywheel like a D. Not in the bottom of the case.
Maark
11-29-2006 17:43:59
Remove the outside cover from the pump gears and pack it full of grease. Replace the cover and see if you get oil pressure then. Sometimes they need to be primed.
P Browning
11-29-2006 16:42:38
Is there a chance that your JD-A tractor's oil pump has what my Dad called a FUSE? It is officially named B250R Coupling which will break if the oil pump freezes up (like with water) thus saving the pump, but at the same time, leaving you without oil pressure.
If that tractor has one, you have to change it out by (1) removing the crankcase cover granting you limited access from the top, and (2) remove the pump gear cover at the bottom of the oil pump. Drain the oil first of course. You have to be careful lest the gear and pump shaft drop out of the tractor. I held a butcher knife under the shaft & free gear for my Dad as he and I worked together to lower the oil pump shaft just enough to insert the new coupling, then raise it into position again & secure. (PatB)
John Cunningham
11-29-2006 15:52:45
Welcome to the world of disappearing oil presure. I have an old a that mysteriously lost pressure and I called everyone in the USA who I thought could help.First check to see if you have oil coming out of the out pipe of the pump. If you do check the ball valve on the bottom of the pump, you may need to put a washer in to make more spring tension.Make sure your plunger is free,it is removable from the bottom,after you take off the oil pipe. If you have oil coming out of the pumpand still no presure remove the spring from the oil plunger and see if it will come up .call if you have trouble 309-662-1903
