JD 520 Power Steering Pump Removal
Mike Siless
11-29-2006 04:05:19
I need to remove the power steering pump from a 520 because the splined shaft is worn out. Any ideas how I can do this without removing the radiator? I've got everything else loose, but am about 1/4" from getting the shaft free of the tube. Is it possible to get the fan off while the pump is still in this position? What about loosening the flange back at the governor housing to gain a little sideways play in the whole tube (I've got the gov gear out)? Once it's out, has anyone had any luck fastening the coupling to a worn out shaft by drilling through and installing a few roll pins? Also, what should I use for power steering fluid in this tractor. Thanks in advance for any advice.
Mike Siless
12-18-2006 08:12:38
 Re: JD 520 Power Steering Pump Removal in reply to Mike Siless, 11-29-2006 04:05:19
The 520 is all back together and after sitting for over a year is now running great! Thanks to all of you for your input. Happy Holidays!
Mike Siless
12-01-2006 10:27:56
Was able to order the coupling and JD PS oil from my dealer. One more question, what's the oil capacity of the power steering system? Mike M...I hear you, but not my iron. If it were my tractor I'd rebuild it.
Mike Siless
12-01-2006 04:10:27
I got the pump out last night. First, replaced the cardboard I had protecting the radiator with sheet metal! Took my sawzall and cut a nice neat notch and everything came out the right side of the tractor without loosening the radiator or removing the oil filter. Pulled the coupling out a bit with needle nose pliers and pushed the shaft back in with a screw driver to free them up. The coupling is completely worn on the pump side and like new on the shaft side. The splines on the pump aren't too bad....not bad enough to warrant rebuilding the pump which otherwise is fine, it's a good candidate for JB weld repair. I'm off to my dealer for the coupling and a gasket. Thanks for all your suggestions and I'll keep you posted.
Mike M
12-01-2006 07:03:04
 Re: JD 520 Power Steering Pump Removal in reply to Mike Siless, 12-01-2006 04:10:27
To each his own ,but I'd never put that pump back in without rebuilding it. Those oil seals tend to get hard as rocks over the years.
Mike Siless
12-01-2006 04:14:36
Oops, I meant without loosening the radiator or removing the AIR CLEANER (at least it's got oil in it!)
D-Man
11-29-2006 08:47:39
Use only John Deere fluid in the power steering-do NOT be cheap. The parts are available or should be and expect to hang your head after ordering them. I think the shaft alone is a couple of big ones, the couplers are reasonable. As for the roll pins I do not suggest but if you replace the worn correctly you will have rejoice in the end. Good Luck.
Mike Siless
11-29-2006 08:40:37
I'm not planning on taking the vent pump apart, I only pulled the gov gears to check those gears first. Of course they're fine, but considering all the gunk on the weights I'm surprised it worked! Good time to clean it. As far as replacing the shaft, let's hope we don't....it's the neighbor's "big" tractor and we just need to get it back in operation.
Ia Ralph
11-29-2006 08:29:44
I just did my shafts about two weeks ago. Take the air cleaner off. The fan shaft tube is 1/4" longer than the casting. Cut a notch in the tube on the left side big enough for the shaft to come through back to the casting. Use a hack saw, a die grinder or even a torch. This will save you from moving the radiator. When you take the crankcase vent. pump apart, pay attention how it comes apart. there is a front and back to it and I could not find a book that told my which.
When you buy the shafts, be sitting down.
Mike Siless
11-29-2006 08:19:23
Thanks for all your suggestions so far. I searched and found a post suggesting the notch and since I'm not lacking much that might work. If not we'll loosen the radiator. Once I get it out, any ideas yet on fixing the splined shaft like gooping it up with JB and installing pins?
Glen in TX
11-29-2006 07:48:48
Use the JD power steering oil and don't whine about the price of it. It works the best. If you moved the governor gears around your going to have to pull governor too and get gear clearance right again. Wouldn't hurt to have I&T JD-16 shop manual either.
Mike M
11-29-2006 06:51:16
Sometimes you have enough room (very seldom)sounds like you allready found this out that you don't. So there's no easy way-- that rad. has to be moved or removed.
machinery-man
11-29-2006 04:59:17
You may need to look in archives...I"ve posted there on same subject as well as others...pretty explanatory....
mjbrown
11-29-2006 04:09:57
I'm afraid you have to remove the radiator, at the very least loosen and tip it. I wouldn't move it around much at the governor. You have gears in there that should stay in alignment. I haven't done this so take that into consideration.
