First project - prototype 2 stroke JD 60?
JD Scott
11-28-2006 21:03:49
Just acquired a 1955 60 (straight gas) barn queen that sat for about 4 years. Drained crankcase and it had about 12 quarts of gasoline diluted engine oil run out. Checked again this morning before adding new oil and filter and drained an additonal 4-6 ounces of pure gasoline that had accumulated again last night. Can gas back feed through the oil pressure activated automatic fuel shutoff or could it be a stuck carb float allowing gas to run into the intake manifold and down into a cylinder (it has weak compression on the right side- maybe a valve hung open?) Tried to start it before I discovered the gas in the oil. Guess I lucked out that it wouldn't run.
JD Scott
11-30-2006 04:38:37
 Re: First project - prototype 2 stroke JD 60? in reply to JD Scott, 11-28-2006 21:03:49
Appreciate the suggestions - hope to have this 60 up and running by Christmas.
Pitalplace
11-29-2006 11:43:07
Head for John Deere, tell the parts guy you need to rebuilt the fuel shut off and he will give you the parts. This is cheap and will fix the problem more than likely.
Gerald J.
11-28-2006 21:30:12
I've read many reports of the diaphragm in the oil pressure operated fuel shutoff leaking gasoline into the oil. So its definitely possible, and seems likely. The only other path is through the carburetor and that takes a leaky float needle valve and enough rise in the intake air line to keep the gasoline from running out there before it runs through the intake manifold to the cylinders and then to the crankcase.
You need a diaphragm, or to depend on a manual fuel shutoff and quit using the broken part.
Gerald J.
