JD 4440 canopy fit 4020??
chart
11-28-2006 15:52:52
I would like to thank you for helping me find a canopy. i found one that a guy had on a 4440, and i was wondering if anyone knew if it is the proper one and/or if it will even fit my 1966 4020 LP. Thanks, chart
Pete/ME
11-30-2006 02:30:11
 Re: JD 4440 canopy fit 4020?? in reply to chart, 11-28-2006 15:52:52
Check part no.s on the JD parts site.
New-Gen
11-29-2006 04:31:55
I"ve seen it done several times, sometimes it looks pretty good, sometimes not so much...all depends on the blacksmith....
msb
11-28-2006 21:12:24
Can't say about a 40 series, but I have seen Sound Gard Bodies adapted to 4020s, so I don't see why a canopy would not fit with a little blacksmithing work.
Ferd
11-28-2006 16:41:56
I know the uprights are different between a 4020 and 5020. On the 4020 they are welded up tubes while the 5020 they are solid steel. Also, the axle is bigger on a 5020 so the base of the uprights is different. So I would think a 4440 would also be different as it's a larger tractor. Also, isn't a 4440 a four post canopy while the 4020 is two post?
