Century LPG Converters
Glen in TX
11-28-2006 13:32:14
Bob "txasylum" and I now know from talking to propane dealers that the LPG model M6 Century converter others speak of for replacement is way overkill probably for our 2 cylinders.
Century M4 = obsolete
Century Model H = 100 hp rating
Century Model G-85 = 135 hp rating
Century M6 = 350 hp rating
Maybe there are just a bunch of NOS M6 out there for sale is why some recommend it but why otherwise? Does it fit with no modifications? Anyone using a M6 on theirs? Thanks.
Tom N Ok
11-28-2006 15:16:38
 Re: Century LPG Converters in reply to Glen in TX, 11-28-2006 13:32:14
Glen I'm replacing a Century model H on my J. D. 730 this weekend with another model H mostly because that is what was on it. The dealer wanted to go with a Impco system but that would have added a lot of cost to add that system. I put a Impco system on my 930 Case mostly because at the time I didn't know what else to do. Ensign had gone out of business and I couldn't find a kit. The only problem I had was I didn't get the Impco Carb bolted to the intake manifold good and that thing sure whistled when I first started it. But the Impco system does work great.
Tom
Glen in TX
11-28-2006 17:43:54
 Re: Century LPG Converters in reply to Tom N Ok, 11-28-2006 15:16:38
Thanks Tom. I'm familiar with the Impco LP products as we have used them for years on irrigation engines and other LP conversions. We found out since I posted this from Nick Barbieri that the Century M6 does bolt right on to the current bracket with no modifications except for having to change one fitting from 3 o'clock to 6 o'clock. Nick has LP parts and you may have seen his ads in the magazines 516-221-4116. Sounds like the M6 will still work okay even though it has the higher rating. Just as long as you only have about 8-12 oz. at carb they should all work fine if large enough rating or larger. I have some NOS M4, M5, and model H basic kits yet. Yeah the Ensign parts are too high now to my liking if you can find them and I did find some NOS parts for those also but many are mixed in bucket and unidentified so guess I'll use them here as needed.
