820 pto problems
BigJim_48
11-27-2006 08:05:42
I'm a new owner of a John Deere 820, and a first time owner of a farm tractor in general. I used the tractor one time to bush hog a field and had trouble getting the pto to engage. I had to shut the tractor off, engage the pto, then crank again. The next time I used the tractor the pto would not engage at all. It felt like there was nothing connected to the lever. Any ideas as to what might have happened?
gtx1967jewison
11-30-2006 09:51:06
 Re: 820 pto problems in reply to BigJim_48, 11-27-2006 08:05:42
the 2 cyl 820 absolutely does not have a disconnect. pto is live, direct to engine crankshaft at all times, regardless of engine clutch engagement. there is only a pto clutch, to turn pto shaft off/on but running or not, in gear, in neutral, etc makes no difference at all. if theres wear it will usually engage easier while running the engine. some of the others had disconnects, such as the 60, & some others but not the r, 80, 820, 830. the ONLY LEVER on the platform for pto is for the PTO CLUTCH.
BigJim_48
11-30-2006 10:08:39
 Re: 820 pto problems in reply to gtx1967jewison, 11-30-2006 09:51:06
Ok, like I said...this is my first tractor. The pto lever is located on the left side under the seat. I thought the clutch had to be pressed before the pto lever could be engaged, but perhaps I was wrong. All I know is that the one and only time I used the pto was bush hogging a field and I pushed the clutch in and tried to move the lever to engage. The pto sounded like gears grinding and would not engage, so I shut the engine off and engaged the lever, then cranked the engine. That process worked fine that day, but the next time I tried to use it (4 weeks later)the lever would just flop back and forth with no resistance and nothing happening - engine running or not. Any idea what happened???
gtx1967jewison
12-01-2006 08:53:41
 Re: 820 pto problems in reply to BigJim_48, 11-30-2006 10:08:39
sounds like you have a 'new generation' 820. the clutch cannot be pressed on a 2 cyl 820- it's a hand clutch with a long lever on right- hand side. does your tractor have a decompression lever on the left side for starting, on the floor near the dash? and a separate brake pedal on each side that sticks up through the floor? just trying to verify we all have the same tractor in mind. do you have a pony motor or electric start? does the engine have a belt pulley on the right side for running machinery?
GAJIM
11-27-2006 14:20:46
Big Jim: I was checking the archives to see if anyone had posted about your PTO problem before and saw that you had already posted about the 820 PTO problem. Any luck hunting at the farm this weekend? JQG
BigJim_48
11-27-2006 15:03:12
 Re: 820 pto problems in reply to GAJIM, 11-27-2006 14:20:46
Hey Jim,
I killed a nice 6 pointer, and got a quick look at the mac-daddy right at dusk Saturday. Bill Bray told me he had seen him cross the road a couple times at the old school house, but he"s too smart to walk out in the open during daylight hours. Hope to get some help with the pto issue on this site. Jim
GAJIM
11-27-2006 15:28:31
 Re: 820 pto problems in reply to BigJim_48, 11-27-2006 15:03:12
Sounds like a "good day at the farm." JQG
MLD
11-27-2006 12:14:23
Wow, thats pretty impressive!!!! A first time owner & started out with the biggest tractor Deere built at the time!!!! I'm of no help, sorry, my first was a 40 standard.
MSM
11-27-2006 09:09:16
Which model of 820,the large 2 cylinder standard or the small utility tractor?
I'm going out on a limb and guess the utility. To engage the pto,the clutch must be depressed fully,before engaging the lever. If you forced the lever trying to get it to engage without engaging the clutch,there is a good possibility the pin has sheared off inside the trans.
BigJim_48
11-27-2006 09:23:55
 Re: 820 pto problems in reply to MSM, 11-27-2006 09:09:16
It is the large 2 cylinder diesel. I didn't try to engage the pto without the clutch being engaged, but it does feel like a pin or linkage is sheared. The lever just flips back and forth with no resistance. If the pin is sheared is this a major repair job?
WeirdDeere
11-27-2006 12:12:29
 Re: 820 pto problems in reply to BigJim_48, 11-27-2006 09:23:55
Just a quick one, gotta go to work.
The 820 does not have a disconnect like MSM describes (the smaller 720 and 620 do). Only the lever for engaging/disengaging the clutches. It is not connected to the main tractor clutch at all, and should not matter if the main clutch is in or out.
I don't know what's going on with yours. The few pins in the linkage are pretty robust...I doubt you broke one. Have someone move the lever while you watch the linkage under the platform. It is pretty simple, you should see any problem.
If it worked before, it should still work now. Maybe one of the yokes came unscrewed in the linkage?!?
Brandon
My Industrial John Deere website
John Deere Diesels
The LaGrange Engine Club
MSM
11-27-2006 10:58:19
If you are shifting the short lever on the floor of the platform,that is the PTO disconnect.It should be shifted with the engine off.It engages the pto gearing in the transmission,and is usually left engaged.The pto has a seperate clutch for implement engagement.
It could have broken the shifter, or a gear. I would suggest getting a service manual or I&T manual before attempting the repairs if you feel you are able.It is not an easy job,with alot of heavy parts to remove just to get to the shifter.
