John Deere A flooding
Al in Mn
11-26-2006 19:53:04
iI am a Farmall man who recently purchased a 1947 John Deere A to do something differnt. It starts fine and runs fine when ideling but when you speed up the engine it smokes black and seems to be loading up on gas. It just does not run right. Do I have ot take the carb off and have it worked on or is there some adjustment to solve the problem?
Al in Mn
11-27-2006 18:19:10
 Re: John Deere A flooding in reply to Al in Mn, 11-26-2006 19:53:04
Thank you for the information, I appreciate it.
Secret Squirrell
11-27-2006 13:10:45
I had one in the shop once that had a spring return on the choke butterfly. It had been assembled wrong at some point. When the tractor idled, it ran fine. When it revved up, the intake suction closed the choke and it loaded up awful. I correctly assembled the choke spring and it was good to go.
P Browning
11-26-2006 20:36:06
Al -- There is a good place to begin. Go to the JD-H Restoration Site (below), one-click on CARBURETORS, then just sit back and take in some basic data about JD tractor single-induction carburetors such as on your JD-A.
As for the flooding -- two things come to mind here (1) the float may be set too high which (in turn) will allow too much fuel into the carburetor, and (2) the IDLE & LOAD needle settings may be too far open thus allowing the engine to draw too much fuel. Good initial settings for the IDLE & LOAD needles are: IDLE from 1-1/4 to 1-3/4 turns out, and for the LOAD, from 3/4 to 1 turn out.
Be very CAREFUL! In order to set the needles, you must first turn them down to the seat & then back off by the amount indicated. WHEN YOU TURN THEM DOWN, GO EASY SO THAT YOU DO NOT DAMAGE THE DELICATE NEEDLE POINTS.
Now -- carb adjustments are a troublesome feat for many. Settings are not critical in starting a tractor. When making carburetor adjustments, engine temperature should be in what we call the operating range -- that is from 180 to 200� -- surely not below 160� -- as many of us try to do! And I won't go into how to adjust the carb in this reply -- your operator's manual has the procedure.
Oh -- BTW, if you do not have the Operator's Manual or Parts catalog for your tractor, call (800) 522-7448 with Model, serial number of the tractor in hand along with your credit card -- and order them!
Also -- while you are reading the piece on CARBURETORS at the JD-H Restoration Site, note that there is a no-wrench test (toward the end) you can perform on your carburetor that will tell if both circuits (IDLE & LOAD) of the carburetor are free of obstruction - like RUST. Running the test can't hurt.
Read the piece, play around some with the carb settings, perhaps run the test; then post back and someone will pick up with you from there.
BTW, Welcome to John Deere Land! (PatB)
