720 pony will not start
toby
11-26-2006 17:59:29
Hey guys over my head with this darn pony motor. I poured gas in carb and nothing so without going further I quit. I will check fire at the spark plugs next. If this fails where do I go from there. I know this is a loaded question but in a hurry they want to pull the FFA float in the Chrismas Parade Saturday.
Thanks Toby
toby
11-27-2006 20:03:28
 Re: 720 pony will not start in reply to toby, 11-26-2006 17:59:29
Guess what (NO FIRE) that is to the plug. Where is the place to get a tech manual because I am clueless about this pony motor. Looks like the parade will need a chain. Also where can I find OEM parts (coils). One last question is the pony positive or negative ground?
Thanks toby
Chuck730DSE
11-27-2006 05:44:12
Toby,
Pony motors are not as scary as some would have you believe. Break it down and use the process of elimination, you will locate the trouble in a hurry.
Compression on all cylinders? You can do this with the spark plugs out by spinning the engine. It is not science but you can tell by putting your finger in the spark plug holes if you have compression. I have had good luck with Autolite spark plugs, they seem to do better than the Champs for some reason.
Next, check and clean the points, set them to factory setting (you must have a JD service manual or you will never get it running)Make sure the connection on the points and the condensors are good.
If no spark, smell the coils, if they smell cooked or burned, they are likely fried and need replacing.
Check all wiring to make sure it is connected with no corrosion and no bad insulation.
I have a pony motor running on 12 volts and have had the same coils in it for almost 5 years. I built a reduction resistor that cuts the voltage to the coils to no more than 6 volts.
Last, be sure you are getting fuel and the carb is set correctly.
Check your oil for gas, make sure there is none it it. If there is gas, change the oil before you start it up.
A cheap volt meter is handy when diagnosing one of these.
Let us know what you find out.
Grumps
11-27-2006 04:58:38
Toby I had trouble starting my pony, I tuned it up with oem parts, it started good a few times and went back to the same old problem. I read about the trouble withthe champion spark plugs, I crossed over to another brand and the pony has started good for a year now.
Grumps
11-27-2006 04:57:59
John T
11-26-2006 19:01:26
Toby, ponys arent me best area other then maybe some on the ignition, so you better be checking for spark the very first thing if shes not ever firing despite gas down its throat. Those pony distributors are known to fry their coils especially if the ignitiion switch is left on for long periods so pull some plugs n wires n see if she sparking and if not you gotta first insure theres voltage getting to the distributors power input terminal when the ignition is on and if so next insure the coil primarys are continuous n not burned open but if they exhibit that classic burned electrical smell they are likely shot. If the coils are okay then check the points for gap and repalce if badly burned or pited or all carboned up.
A neighbor can always help pull start it for the parade right???
John T
