1997 JD5575 Skid Steer
nlwalker
11-26-2006 08:25:42
Hello to all. I own a 97 jd5575 loader. Here recently I began hearing a terrible whining/grinding noise whenever I use the right-hand drive control lever(steering and backing to the right). Anyone know what my problem might be?
MSM
11-26-2006 08:41:24
 Re: 1997 JD5575 Skid Steer in reply to nlwalker, 11-26-2006 08:25:42
Loose drive chain, bad wheel bearing(s),low on oil,contaminated oil,drive motor going bad,one section of the hydro pump cavitating,or going bad,improperly adjusted parking brake,clogged suction screen or filters.Choose one or more of the above,and I would not run it any more until repaired,if it is loosing a pump or motor the metal particles will play he!! with the hydro system.
