Hig5060 -- The JD 7663 Thrust bearing has disintegrated! It has come apart and the parts have escaped over the years. Chapter five of my book, JD-H Restoration Guide, 2nd Ed fully explores the steering on your tractor -- and is probably well worth the price to you for the steering issues alone. You can read about it at the JD-H Restoration Site (below) and decide for yourself. The criteria for free movement (end play) of that vertical spindle shaft is a maximum of 1/32" and this amount is adjusted by varying the quantity of 1/32" thick shim washers under the eccentric bushing. Again, all this is well laid out for you in the JD-H Book. The long & short of it is that there is no way that tractor can be safely operated in either of its two road speeds until the issue is resolved. In a few words, you need to positively ID the parts you need in addition to the bearing, being sure to have checked the lock screw holding the eccentric bushing and the tapped hole it fits into beforehand. Be prepared to take care of all the little anomolies at the same time. I soon will have checked it out, but at this point I can only report -- I have been told that an ordinary fillister head machine screw (or an Allen Head Machine Screw), (size 3/8 x 3/4") will do quite well in for the 19H 205R lock screw should your dealer be unable to sell you one -- and I highly recommend renewing that screw after over 50 years on the job! Removal of the vertical spindle shaft is the one thing no one desires to tackle. As in a cat-skinning, there is more than one approach. You can make a hoist to lift the front end of the tractor up high enough so that the shaft can be extracted, or you can unbolt the pedestal and work it that way. Either way, you will need some hoist assistance and at least one able-bodied helper. The helper, if nothing else, can come in handy moving chock blocks from here to there! You can write or call me to comisserate the old gal if you feel so led. (830) 627-0430. (PatB)
