Fuel leak at injector pump timing cover on 1520
Flatbroke farme
11-25-2006 19:33:22
Have a diesel 1520 tractor, runs very erratic, new fuel line from the tank and new fuel pump. Checked the timing window on the injector pump and the fuel just pours out. Does this mean I need a new / rebuilt injector pump?
Sincerely Steve
jdemaris
11-25-2006 20:12:35
 Re: Fuel leak at injector pump timing cover on 152 in reply to Flatbroke farmer, 11-25-2006 19:33:22
When you say you checked the timing window - what do you mean? It has a ten-cent gasket on it, and inside the pump there is fuel. If the gasket is damaged, the fuel will leak. So, I guess I don't understand. The pump is supposed to be full of fuel, and under about 6 PSI of pressure when running -that is normal. If you take the window off - fuel is supposed to come rushing out.
Flatbroke farmer
11-25-2006 20:18:32
 Re: Fuel leak at injector pump timing cover on 152 in reply to jdemaris, 11-25-2006 20:12:35
I am trying to determine if the injector pump is bad, if the advance assembly is shot wouldn't there be fuel leaking into that part of the assembly? I am not too familiar with these units.
jdemaris
11-26-2006 06:46:06
 Re: Fuel leak at injector pump timing cover on 152 in reply to Flatbroke farmer, 11-25-2006 20:18:32
Why do you suspect the advance? The advance operates by fuel pressure - created by a vane-pump in the back of the injection pump. That pressure if fed to an advance piston that has sealing rings. If it was leaking, the timing would not advance properly - but it would not create any visible leaks. Again, the pump is supposed to be full of fuel when all is fine. Are you sure you're not referring to the plastic weight retainer in the governor as used in the Roosamaster/Stanadyne pump? A few foreign-made 152s use the CAV pump instead - which is a licensed copy of the Roosamaster -but has no plastic ring in it.
Flatbroke farmer
11-26-2006 16:04:27
 Re: Fuel leak at injector pump timing cover on 152 in reply to jdemaris, 11-26-2006 06:46:06
I sincerely appreciate your time spent on this discussion. Maybe I should start at the beginning as I may have misled this discussion by jumping to my own premature conclusions. The tractor in question is a 1520 diesel, and the engine runs rough. It skips and hunts and even on occasion runs perfectly. This tractor is new to me, so its history is a wild guess at best. The previous owner said the engine was "rebuilt" which could mean anything, but the fuel injectors look brand new, there is a new fuel transfer pump and a new fuel line from the fuel tank. The block is very clean and looks like it was worked on, but again it is a guess. The tractor starts well, and smokes slightly when working hard. I think we have eliminated any possible air leaks into the fuel system, so now I am suspecting the fuel injector pump assembly. (Stanadyne). With the engine off, I removed the timing window cover, and the fuel just poured out, so I initially thought there could be a problem there, I thought that the casing was dry and that any fuel would indicate a failed component such as the advance. I do not know of any way to check for problems with only farm resources available. I dont want to end up just changing out expensive parts and maybe get lucky. A knowledgeable decision would be best. Again, I am looking for clues to make it run correctly, I suspected the fuel injection pump and thought that fuel pouring out of the timing window might be a clue. One last thought, a diesel mechanic that rebuilds these pumps said the operating life on these pumps was only about 3500 hrs, Never heard that one before, is there any foundation to this claim?
Again thank you for your time.
jdemaris
11-26-2006 16:18:19
 Re: Fuel leak at injector pump timing cover on 152 in reply to Flatbroke farmer, 11-26-2006 16:04:27
I have seen some of those pumps last 30,000 engine hours - except for two parts that tend to fail. Those two parts can be updated - and usually are. The same basic pump your tractor has was also used on Chevy and Ford diesel pickup trucks. Up until 1985, there was a plastic dampener that had a short life and would fall apart. There is a new component that can be used, to take its place - and IT won't fall apart (EID ring). EID stands for elastic insert dampener - or something like that. When the ring first breaks, the little chunks work around the pump and often plug the fuel-outlet on the top. The engine will run good somtimes, sometimes it will stumble, eventually it will start to quit when worked hard - but once off - it will start right up again. When you took that door off, there were probably some small dark chunks in there that look like mouse turds. Same goes if you take the top off the bump via the three little bolts. If you can find someone that is willing to work on the pump, it can be pulled apart, new style dampener put in, all new seals, drive bushing, etc. in about two hours time (on the bench) and $60 in parts. If you have to send it out to a shop - you will likely be charged a flat "rebuilt pump" rate - probably in the range of $400-$600.
And, keep in a mind, most "rebuilt" pump retain most of their used parts - it's not the same as a rebuilt engine.
