oil for JD 70 Part II
txasylum
11-25-2006 13:59:51
Below is a summary from a previous email:
How much oil does the PTO hold? I understand 20 or 30 weight hydralic oil for PTO.
How much does the engine hold? I understand 30w motor oil.
For the tranny, 7.5 gallons of 80w90 or straight 140w.
I see where the tranny oil goes, but I can not find where the engine (30w) oil goes. Can someone help?
Thanks
Bob
Do I have this correct? bob
55 50
11-26-2006 10:57:08
 Re: oil for JD 70 Part II in reply to txasylum, 11-25-2006 13:59:51
You said you have the Owner"s Manual. It tells you all these answers if you will only use that Manual!!!
Glen in TX
11-26-2006 12:04:21
 EXPLANATION of manual for LPG in reply to 55 50, 11-26-2006 10:57:08
He may only just have the 70 LPG supplement operators manual which does NOT have capacities and other needed info. That's why he may also need the regular 70 gas/all-fuel row crop operators manual as well. JD made LPG supplement operators manuals seperate or different operators manuals for all the LPG tractors and different manuals for diesel models as well so that's why it important to have the proper manuals!
txasylum
11-26-2006 10:59:18
 Re: oil for JD 70 Part II in reply to 55 50, 11-26-2006 10:57:08
The owner's manual I have is pretty basic and only tells you how to run the tractor and how to set the points. That's about it.
billde
11-25-2006 14:48:19
PTO should be 2 or 21/2 quarts.
Engine, fill til it comes out the test cock, I think 11 quarts.
billde
11-25-2006 14:44:26
there is a pipe cap on the top of the block to the left of the belt pulley [clutch] about a 1 inch pipe this is for the engine oil.
txasylum
11-25-2006 15:21:26
 Re: oil for JD 70 Part II in reply to billde, 11-25-2006 14:44:26
Okay, that is the 7 1/2 gallons of 80w90. That is what I assumed.
Speaking of oil, I just came from Walmart and they have a SuperTech Heavy Duty Tractor Hydraulic and Tranny oil. The back says it can be used for PTO, tranny, and Power Steering to mention a few. Has anyone used this stuff before?
Bob
buickanddeere
11-25-2006 15:26:22
 Re: oil for JD 70 Part II in reply to txasylum, 11-25-2006 15:21:26
Many people have blammed everything except their bargan oil they dumped into the two cylinder Deere power steering system. Trans/hydraulic fluid will help identify any leaking gaskets and seals in the transmission.
