1010 RS/ cultivators
orangepower
11-25-2006 07:18:04
Do the front and rear cultivators operate independently of each other or do they raise and lower at the same time? I"ve read the 1010 RS is slightly offset for a better view of the cultivators. Is it offset enough to make a difference? From the pictures I"ve seen of the RS tractor it looks like the engine is pretty much centered over the axles. Do they make a good single row cultivating outfit? Thanks.
Dave in North Ohio
11-25-2006 08:37:53
 Re: 1010 RS/ cultivators in reply to orangepower, 11-25-2006 07:18:04
On my 430 S (predecessor to the 1010) the cultivators operate independant of one another. There are two lift arms on the left side of the tractor (as you sit on it). . . one raises/lowers the front rig while the other works in tandem with the right side to run the rear rig bar. The engine on mine seems to be set in the middle of the tractor but you can adjust your front axle and rear rim (I believe more so on the right side) out to get a better view while cultivating.
