A hand start to electric
RLH
11-25-2006 04:06:03
Im thanking about changing 41 A hand start to electric will any top starter flywheel fit has anyone done this any imfo would be appreciated thanks for your help
JDBert
11-27-2006 08:52:08
 Re: A hand start to electric in reply to RLH, 11-25-2006 04:06:03
I've got all the parts for the conversion if your interested. I'm in SW MN.
RLH
11-25-2006 04:10:04
I forgot to ask where is part number on flywheel is it on inside
zwr
11-25-2006 19:10:53
 Re: A hand start to electric in reply to RLH, 11-25-2006 04:10:04
Why would you want to change it? The hand start feature adds a lot of charm and probably adds to its value also.
Your nearest JD ag dealer should be able to cross reference flywheel numbers for you. The starter mounting bracket from factory was a single casting with the tranny cover. Your dealer should be able to give you a number that will replace your existing cover. Most JD castings of that era had the part number cast right into the part.
