Dip Stick Location on a 46 B
Gimpl
11-24-2006 23:10:40
Ok, I have spent way to much time trying to find the dipstick on this thing. Can anyone tell me (nicely) where this is located or if it has one. I just bought the tractor and would like to change oil.
Also does this have a filter and if so where is this along with the drain & fill locations.
thanks Guys...
B-maniac
11-25-2006 18:55:20
 Re: Dip Stick Location on a 46 B in reply to Gimpl, 11-24-2006 23:10:40
"Nicely" , I can tell you've been around these forums a little while. Since no one answered your first question , I will. There is no dip stick. Glad you picked a "B"! Once you have all the manuals etc , you will love the little "popper" even more. Enjoy!
j cook (iowa)
11-25-2006 16:30:59
Buy the OM and the parts catalog. However, there is also, of all things, a MOTORBOOK which might actually be of use to you called "JOHN DEERE MODEL B Restoration Guide" by Robert N. Pripps which contains many illustrations from the Parts catalog and much useful text discriptions.
P Browning
11-25-2006 06:12:33
Gimpl -- The Waterdoctor provided helpful information for you. But bottom line, be kind to your tractor! Just leave the tractor sit until you have in hand the operator's manual and part catalog at minimum. How and where will you find these? Here is a site that will help you in that goal. Have the serial number for your tractor in front of you. Go to the JD-H Restoration Site (below). On the left side, scroll down to DEERE PUBS & one-click. Allow the document to come up. Here you will find which manuals you need & how to obtain them. (PatB)
Waterdoctor
11-25-2006 00:21:43
Look on the left side of crankcase below flywheel, almost down to bottom. There is a fitting that resembles a pipe bushing with a plug in it. Turn the outer fitting to the left as to remove it, There is a hole in the outer fitting that the oil will run out. The fitting you loosen will come out making it self explanatory how it works. I have seen them on opposite side of case in same place.Drain and filter are underneath.Get an operators manual or an IT manual as they would show you or e-mail me and I will send you a picture out of my book
