1950 A eccentric bushing side play
gurneejoe
11-24-2006 20:38:43
I was trying to investigate the side play in the vertical steering shaft today and after cleaning all the grease out of my gearbox (I know it is supposed to be oil. I didn't do it.)I found a lot of side play in the eccentric bushing. It appears as if there is a replaceable bushing in the pedestal but it doen't show it in the parts book or mentioned in the service manual. It seems odd that it would need one or be worn since the eccentric bushing doesn't normally rotate. Mine had the bolt in place. Not damaged. Any ideas?
Mike M
11-25-2006 20:16:41
 Re: 1950 A eccentric bushing side play in reply to gurneejoe, 11-24-2006 20:38:43
I have had some before that someone had modified by drilling and taping the casting and put set screws in to tighten up against that eccentric bushing. I had no idea this was done and chewed up that bushing trying to drive it out. Can't really recommend it but it will take out that play.
gurneejoe
11-25-2006 17:59:47
It is unfortunately dawning on me what you are saying Pat. I did get two other bushings from other tractors from a tractor graveyard near Whitewater. One looks like the original early design and one is similar to the one in the 1950 A. The one that was in the tractor has a relief about 1/4" wide machined around the middle with a 1/16" hole drilled through the side of it. All three are the same but a little different. I will see if I can find my micrometers and see how they compare OD wise. I am not looking forward to removing the pedestal, but do want the tractor to be able to run reliably and be safe on the road between the farm and field.
gurneejoe
11-25-2006 15:26:56
I have been studying your books and the service manual Pat but it seems like the inside of the bushing has no play around the pedestal shaft, it is the outside of the bushing in the pedestal. Is there a bushing in the top of the pedestal housing that is serviceable? I don't see one in the parts book although in looking in there it seems like there is one in there. Do you know if all of the eccentric bushings are the same diameter? By the way, thanks to all for the interest and help.
P Browning
11-25-2006 15:58:16
 Re: 1950 A eccentric bushing side play in reply to gurneejoe, 11-25-2006 15:26:56
Wear over the years between the pedestal cavity and the eccentric bushing happens because the bushing was allowed to roam, and what allows a bushing to roam is the lock screw coming loose. Whatever corective action you take, restoration of the tapped hole for that screw and a new screw must be in your plan.
No -- there is no additional bushing between the eccentric bushing and pedestal. A replacement eccentric bushing will no doubt reverse lots of the wear, but unfortunately, there will also be some wear having taken place in the casting. I have in past times built up the outside of the eccentric bushing so that it was quite snug in the pedestal. That was very difficult -- took lots and lots of patience. In a full restoration, I think a better course of action would have been to overbore and rebush the pedestal and also renew the eccentric bushing at the same time. This is a machinist's solution. The design just will not work so long as the eccentric bushing is free to rotate ANY at all! (PatB)
Glen in TX
11-25-2006 08:57:58
It's not odd or uncommon at all to find lots of wear in steering parts there. Things can be rebuilt to like new or if lucky find NOS or better used parts. Some have fixed it by putting the band aid on it and drilling top side of pedestal on opposite side of worm gear to tap in a bolt with lock nut to push the sector gear shaft over closer to the worm taking slack out. Many have done it on them but if it still binds or a working tractor you might as well pull it all apart and get it fixed right.
P Browning
11-25-2006 06:35:26
gurneejoe -- This is an area of JD tractors that gives many fits. My Book, the JD-H Restoration Guide, 2nd Edition deals comprehensively with steering issues such as yours. Corrective action can be expensive, but at least needs to be creative! You stand to save (at minimum) the book's cost as a result of its guidance. See Chapter 5 excerpt below.
You mentioned grease used to lubricate the steering gears as opposed to transmission oil. Use of grease (corn head grease preferably) is the way these gears were lubed in the early years. Later guidance (1939) made the change to transmission oil. And (of course) there was some confusion there how much to use. It turns out that if oil is used, it should be added only until the oil level is at the BOTTOM of the sector gear. Too much and you have leaks.
One note about that lock screw -- more often than not, that screw will be at the heart of faults involving a moving eccentric bushing. It is a special screw with a head the right size to fit snuggly into the notches of the eccentric bushing. One fellow found that a 5/16 x 1/2" Hex Head Cap Screw (Allen head drive) did the job nicely in place of the special screw. Also, be advised that if the threads for the lock screw are sloppy, you must deal with that -- and you have limited choices -- one of which is to over-drill and install a helicoil (or keensert). (PatB)
VARIABLES IN LOOSE STEERING -- for the "H" Tractor -- PC304, page 31 -- The list of contributors are the 19H89R Lock Screw (20), worn spindle shaft (where it rotates in the eccentric bushing), the H200R Sector Gear (40), the H197R Eccentric Bushing (21), the worm-gear on the end of the steering shaft, and finally the H270R/271R/272R gaskets (4), the quantity of each to be determined during the worm shaft end-play adjustment.
LOCK SCREW -- Over time, the 19H98R Lock Screw is prone to loosen. No lock washer is used here. Periodic maintenance should catch looseness, and result in correction. When loosened, the H197R Eccentric Bushing is permitted to rotate back and forth as the tractor is steered to the left and/or to the right. Several unintended wear points result: (1) the 5/16-18 tapped threads in the pedestal casting wear/erode, (2) as the eccentric bushing rotates to and fro, wear takes place to reduce the bushing's OD and the pedestal casting's ID at the interface of these two parts, and (3) the lock screw itself is worn losing diameter, thus allowing even greater to and fro motion of the bushing.
Excessive wear of the spindle shaft is a direct result of a "dry interface". Poor preventive maintenance to include periodic lubrication for steering components is very common.
SECTOR GEAR -- The H200R sector gear is of marginal design to begin with. The most common faults are worn teeth that resulted from (1) lack of lubrication (poor maintenance), and (2) out of tolerance backlash adjustment (too little engagement of its teeth with worm shaft gear). A less common fault is lack of a tight connection between the spindle shaft and the gear. This can be a result of incorrect spindle end-play adjustment, or failure during installation to fully tighten its retaining nut. Or perhaps the cotter pin was not installed. See Figure 506 and comments below it.
WORM GEAR -- The final variable in this series is the steering shaft worm gear itself. Your hope is that by curing other ills, performance standards can be met by making the prescribed steering adjustments. If so, you will be able to find the worm gear serviceable.
CORRECTIVE ACTIONS --
Dave in SV
11-25-2006 03:44:14
Checkout page 103, item #22 in the PC675 Parts Catalog for the part. See page 10, paragraph 18 and on in the I & T JD-4 Shop Manual for adjustments. I've never worked in that area, so I don't have a clue of what it takes...
