1948 JD model A carburetor
Tcb
11-24-2006 14:33:24
Hello Guys, I recently purchased a 1948 JD model A in non running condition. First off it wouldnt fire the spark plugs. I worked on the magneto and got spark but then discovered another problem. The previous owner had globbed a bunch of silicone on the bottom of the carburetor bowl to hold it on. The threads of the stem of the DLTX carburetor has been broken off. Is it possible for the home mechanic to repair these without spending $125.00 plus just to repair these threads? One other note I understand that this JD-A should have a Marvel Schebler DLTX 71 carb on it. I cant quite make out the model on this one but its either a DLTX 62 or 67. What is the difference between this and the DLTX 71? is it the throat diameter?
Thanks for any help.
Tcb
Mike M
11-25-2006 20:30:14
 Re: 1948 JD model A carburetor in reply to Tcb, 11-24-2006 14:33:24
Where there's a will there's a way ! I had repaired several of these many years ago by custom makeing an adapter I think it was 5/8 fine thread on one side and 7/8-18 on the other end. I tap the end of the inner stem and then fit in the adapter. I'd have to use a cut off spring to hold the nozzle in place and also cut a groove into the side threads of the adapter indexed to where the fuel comes into the center from the side of the stem. I've heard of alot of them being fixed by that method of using an old spark plug end and brazing it on too.
Tcb
11-25-2006 05:58:15
Thanks to all, your suggestions are appreciated.
Tcb in Georgia
Paul from MN
11-24-2006 21:41:56
The stem is not a simple repair. Call Robert Beaver at Robert"s carburator repair. 712-262-5311
He does very good work and I am sure they can do this. The stem must be perfectly straight and also have a smooth and precise inner bore to hold the nozzle.
Good luck.
Glen in TX
11-24-2006 21:40:08
Lots of people have repaired their own on the threads by cutting off 7/8-18 spark plug threads from a old plug. Then cutting back carb and welding the new threaded ring on carb. Or can make a collar to weld on also threading it 7/8 inch diameter x 18 thread per inch. If you aren't much of a welder it will be better to find someone else to do it or trade your carb in on another rebuilt one.
P Brwoning
11-24-2006 16:02:58
Tcb -- for openers, take a short trip over to the JD-H Restoration Site and when you arrive, one-click on CARB ID CHART over to the left side. You will find where to look for your Carb's ID number, and which carburetors were installed on each model tractor. If you come up with a number not on the chart, you are probably reading the part number of a part of a carburetor. (PatB)
