JD 430 steam out crankcase ventilator cap
TD
11-23-2006 18:03:15
On my JD 430, engine was rebuilt a few years ago, and tractor has sat for the past 3 years, however each year it was started and ran up to operating temp. It has very good power, very good oil pressure, prestone in rad does not go down,and does not have any water in oil. I have changed plugs, points and condensor, also oil was just changed and it seem to get worse, when you use it. First thought it had some blowby, but it appears to be steam coming from the ventilator cap. Also it does not use any oil what so ever, my question is, could it be possilbe that the rings are not seating due to not being used regularly?
Thanks in advance
Mike M
11-24-2006 04:01:29
 Re: JD 430 steam out crankcase ventilator cap in reply to TD, 11-23-2006 18:03:15
"engine rebuilt" can have several meanings to different people. Was it bored out and new correct oversized pistons installed ? Did the machine shop bore it too big for your pistons ? I had one do this to me on a JD B. But it doesn't show up until very warm and worked hard. Or perhaps it just needs a good hard workout.
CPeter
11-23-2006 18:09:32
Probably condensation evaporating from the crankcase. If you only start it once a year, it collects a lot of moisture in between and when the oil heats up it evaporates.
CPeter
