How can you tell piston position on a 2 cyl?
Sam S.
11-22-2006 19:57:46
I keep hearing, turn over the engine by hand until the #1 exhaust valve just starts to open, or #1 piston is TDC of compression stroke, etc, etc, etc.
How can you tell exactly where the engine is at, with all the covers in place? Feel? Sound? Open the Pet-Cocks?
I have a 48-A and have not figured that one out yet. Can you please help?
Thanks,
Sam
Glen in TX
11-23-2006 10:57:04
 Re: How can you tell piston position on a 2 cyl? in reply to Sam S., 11-22-2006 19:57:46
Sam, You never said if you were trying to set and time valves or just magneto. Like John T said there is mark on flywheel and cover for it to be at 6 o'clock on later tractors. If the governor slots where mag mounts need to be horizontal when you get LH piston on TDC compression stroke. Pasted my generic flange mount mag timing instructions. Operators manual and and I&T JD-4 shop manual will give these instructions along with valve timing too.
Magneto Timing for JD D and other Waterloo JD tractors with flange mount magneto :
1. Remove spark plugs from the engine and turn flywheel forward in direction it runs until you feel some pressure of air coming out the LH # 1 cylinder (flywheel side) spark plug hole as it is coming up on compression stroke. (If you don�t feel or hear air coming out it is on exhaust stroke and keep rotating till it comes up on compression stroke.)
2. Turn slowly as it comes up on TDC (top dead center) of compression stroke and watch as the mark on flywheel �L.H. Impulse� comes up in line exactly at the 3 o�clock position with the mark on transmission cover or housing. Stop when marks are in line with each other. (Note): The later model A,B,AR, & 50 tractors with flywheel cover will have a mark or notch on lower end of cover hole to align with flywheel punch mark instead of marks mentioned above.
3. In this position the slot in coupling on governor shaft should be horizontal. If it is not horizontal when LH cylinder is at TDC and governor had been removed previously this will have to be aligned and corrected first.
4. If slot is now in horizontal position you are ready to install the magneto.
5. Make sure points are set at .015� for Edison Splitdorf and Wico magnetos.
6. Edison Splitdorf magnetos when mounted use the forward terminal on distributor cap for # 1 LH cylinder. Can mark with chalk if necessary. 7. Wico magnetos will use the top terminal in distributor cap for #1 LH cylinder. Can mark with chalk if necessary.
8. Connect wires and spark plugs in distributor holes of magneto and have the magneto frame and plugs grounded with plugs out of engine.
9. While turning the magneto slowly in a left hand direction (CCW) facing the drive end watch for a spark from the #1 LH cylinder plug that would be connected to forward terminal on Edison magneto or top terminal on Wico magneto.
10. When you get a spark on the LH terminal stop and the drive lugs of magneto should be in a horizontal position. 11. Being careful to not disturb that position install the magneto on tractor using one or more flange gaskets and install bolts only finger tight.
12. If you notice a binding and magneto flange does not pull up tight to flange when tightening bolts finger tight you may need to shim out with more gaskets being careful drive lugs align in slots also.
13. Then rotate the top of magneto toward the front of tractor as far as possible.
14. Then slowly rotate the flywheel forward one complete turn slowly coming up on the �LH Impulse� mark on flywheel to align exactly again with cover mark at 3 o�clock position. Then stop in this position. 15. If you went past the mark you can rotate the flywheel back and come up on mark again but if you rotated too far forward and tripped the impulse in magneto you will have to remove magneto and start over. 16. Now carefully and lightly tap the top of magneto slowly toward the rear of tractor a little at a time until you hear the impulse trip. Stop.
17. Tighten the bolts holding magneto to governor case taking care to not over tighten. If flange does not pull up flush do NOT over tighten to pull it up more.
18. Use another gasket to shim magneto farther out instead. Failure to heed this advice shimming the magneto properly with gaskets can result in breaking the magneto housing. 19. Problems getting magneto to align by having to use several gaskets may also indicate previous improper assembly of governor or worn governor parts.
20. Gap spark plugs at .030� before installing in cylinders. 21. Install spark plug wires so wire in upper terminal of Wico magnetos or forward terminal of Edison Splitdorf magnetos is connected to the LH cylinder spark plug. Lower or rear wire connects to RH cylinder.
22. If magneto is equipped with a threaded stop terminal you may add a shut off grounding switch to this terminal.
23. NEVER connect battery voltage to a magneto or to stop terminal !
24. A magneto produces it�s own power and does not need power from a battery.
John T
11-23-2006 07:07:48
Sam, for one thing when you hear me at least talking about starting on the No 1 cylinder thats cuz its a hand start tractor, but if she's an electric start its not critical. I forget if your tractor has the lil removeable round center hub in the flywheel cover??? (think thats on later models??) On those tractors with the lil round sheet metal center removed theres a dot on the crank/hub thats in the 6 o clock position when the left no 1 cylinder is at TDC (but still at both power and exhaust). Other then this you gotta do like Glen mentioned nnd remove the left spark plug to find its TDC.
John T
Glen in TX
11-22-2006 21:34:37
Take the spark plugs out grounding wires or plugs and it will be easier to turn over. Then roll forward and when you hear or feel air rushing out of LH cylinder it is coming up on compression stroke and LH Impulse or LH retard spark mark coming around to 3 o'clock position you are nearing TDC top dead center. Sometimes will also see punch marks on flywheel at 3 o'clock position where someone has marked true TDC on flywheel.
Gerald J.
11-22-2006 21:00:58
Certainly a petcock ceasing to push out air would show the end of the compression stroke on that cylinder. Often one feels the increased torque required to turn the crankshaft during the compression stroke. One sometimes pops a valve cover and notices the strokes when the valves are both closed (compression and power).
Then on some two cylinder tractors these event labels are cast as part of the flywheel. So one determines the reference point and reads the flywheel.
Gerald J.
