404 modifications
5020s rock
11-22-2006 17:56:03
hello fellow deere admirers. has anyone taken a 404 w/turbo and converted it to a non-turbo?
if so what needs to be done besides changing the manifolds? also, what tricks will you share for "freeing up" a stuck 404? thanks
JDBert
11-27-2006 07:17:22
 Re: 404 modifications in reply to 5020s rock, 11-22-2006 17:56:03
The only problem I would see is 404T's have a lower compression ratio- so it would start hard-BUT then what 404 doesn't??
5020s rock
11-23-2006 16:48:19
thanks guys!!! i want to put this motor in a 4020. i have seen guys leave the turbo on,im not sure if it would fit under the hood. i didnt
think about the inj. pump, good point. more, more.....
Mike M
11-23-2006 04:25:27
If you have a Factory Turbo set up engine why would you ever not want to use it ?? It should help fuel economy.
4010
11-22-2006 18:39:28
What was the 404 out of? Maybe interested in the turbo set up, and manifolds.
5020s rock
11-22-2006 19:05:26
 Re: 404 modifications in reply to 4010, 11-22-2006 18:39:28
hey,hey a response. the motors are from
7700 combines. shoot me a price. can you steer
me anywhere on my question? would you share a couple good deere sites? tractor data,this one
and 4020.com are all i have to work with.
Tx Jim
11-23-2006 03:44:40
 Re: 404 modifications in reply to 5020s rock, 11-22-2006 19:05:26
If you don't need the HP I see no reason one couldn't remove turbo. I would rather run a turbo engine without one than a non-turboed one with an added turbo. If your going to run inj. pump that came with turbo it might need turning down. Tx Jim
