engine rebuild info needed
Bill Ross
11-22-2006 11:30:06
I have two different questions... 1st, I have a 1520 gas repowered with a 152 diesel. It is getting a bit tired and I want to give it a boost. Can I buy a rebuild kit and make it a 179 cubic inch? It is my thought the crank and all are the same and I can just put new bigger sleeves, but I a wondering about balancing.
Second, can you install a 55 series head on a jd 4240 engine and still have clearance for the valves from hitting the pistons? any help greatly appreciated. Thanks
jdemaris
11-23-2006 06:25:08
 Re: engine rebuild info needed in reply to Bill Ross, 11-22-2006 11:30:06
You're not going to jam a 4.19" sleeve from a 179 engine into a 152 engine made for 3.8" sleeves - unless you plan on machining the block somehow - and I have no idea if the block has enough metal in it - most likely it would be weakened. As I recall, when Deere first came out with the 179, the block was beefed up quite a bit.
