40-41 JD B DIFFERENCES?
PHILLIP W.
11-22-2006 09:09:05
IS THE SHEET METAL AND FUEL TANKS THE SAME BETWEEN A 40 AND 41 B? ARE THE AXLES THE SAME? WILL ANY OF THE ENGINE PARTS INTERCHANGE? I HAVE A LOCKED UP 41 AND FOUND A RUNNING 40 AND WOULD LIKE TO MAKE 1 OUT OF THE 2.
Mike M
11-22-2006 13:33:54
 Re: 40-41 JD B DIFFERENCES? in reply to PHILLIP W., 11-22-2006 09:09:05
I think you will find very little in common.
PHILLIP W.
11-22-2006 12:28:15
I DID FIND OUT IT DOES HAVE A 4 SPEED AND THE GAS TANK IS SET UP LIKE AN UNSTYLED WITH THE 2 TANKS ARE ONE UNIT. ANYONE HAVE A GOOD HOOD FOR A 39 OR 40? THE GAS TANK HOLES ARE CLOSER TOGETHER THAN THE 41 AND NEWER B"S.
DickD
11-22-2006 11:11:48
Phillip; The hood and gas tank on the 39 40 are unique. The filler holes are closer together on these than any of the others. The grills, and medallion are interchangeable.
WTW
11-22-2006 10:21:17
There is some things the same and allot of things different from the two year models. 39 and 40 models are basically the same tractor but when comparing them two years to a 41 there is many differences. Four speed verses six speed, Different engine block, head, rods, pistons and crankshaft are all different on the 41. Some transmission gears are the same. I think the grill screens are the same and maybe the hood. Radiators are different due to different type mufflers were used. Original manifolds are different. Rear axle shafts and housings are the same. These are some of the differences I can think of right off the top of my head. DW
old
11-22-2006 10:01:15
Well I think you will find other then the years they are the same tractor. Now if it was a 1938 and a 1940 ya then there are big differance in them sine 1938 was the last year of the unstyled tractors
