What are the tire lugs called?
txasylum
11-22-2006 06:57:55
I have a JD 70 and the rear wheels are mounted on the rims, which are attached to the hub by several (8 I think) independent lugs. I am missing 4 of them, but can't seem to find them in any catalogs. I don't know what they are calling these items, so I may be looking in the wrong sections. Anyone know what these things are identified as in the catalogs?
Thanks
Glen in TX
11-22-2006 08:44:20
 Re: What are the tire lugs called? in reply to txasylum, 11-22-2006 06:57:55
If row crop most likely A4388R and if standard probably B684R. Didn't have 70 book to check it exactly. I only had two B684R but no extras of others. Get the correct bolts and grade 8 nuts from JD too if they are worn or bad. JD Parts showed this at Clovis, NM store. Part Number: A4388R Part Price: 8.55 USD On Hand: 24 Check Other Stores Description: CLAMP, RIM Also you are close to the wheel place at Lubbock so they might have some too or even the step up lugs to go to other size rims if needed.
txasylum
11-22-2006 09:43:55
 Re: What are the tire lugs called? in reply to Glen in TX, 11-22-2006 08:44:20
I called my local JD (San ANgelo), they didn't have on hand, but were able to order 4 for out of Dallas. Should be in next week.
I have to replace the tires on this tractor before I can tow it 10 miles to get it home. Might be a long ride at 15 miles per hour.
Bob
txasylum
11-22-2006 07:19:56
Thanks for the quick replies.
Bob
Glen in TX
11-22-2006 07:14:28
 Example.. in reply to txasylum, 11-22-2006 06:57:55
Part Details
Part Number: B634R Part Price: 6.41 USD
On Hand: 0 Check Other Stores
Description: CLAMP, DRIVE WHEEL RIM
jhill52
11-22-2006 07:08:13
I think you mean clamps.
Glen in TX
11-22-2006 07:07:40
Clamp--rim, Rim clamp. I'm not sure of number for your 70 but might be B634R ? See a number on others? JD probably still has them as the same clamps were used on many tractors.
