8400/8300 tractors
kojak
11-22-2006 06:08:53
Are 8400 tractors only large 1000 pto shafts or can they be changed to small 1000 / 540 like 8300's? Also I found an 8400 with very short axle(not able to put duals on) and a hand brake set up. Is that a foreign built tractor?
J. Stacey
11-23-2006 08:52:36
 Re: 8400/8300 tractors in reply to kojak, 11-22-2006 06:08:53
All 8000 series tractors can either have the big 1000 or they can also have the optional big 1000 small 1000/540 pto kit. If the tractor has the big 1000 it can be switched over to the other optional pto set up. If your dealer has another tractor with the optional pto they can be switched with each other in about 3hours or so. The switch is easy.
MSM
11-22-2006 09:27:26
It will depend on how the tractor was ordered. The 1000/540 pto was an option.They could have come big 1000 shaft only,big 1000 shaft/540 or small 1000/540. If it is a foreign market tractor,it may have a pto that looks like a regular 540 shaft,but also spins @1000.A trip to your dealer with the serial number would answer your questions.
stuart
11-22-2006 07:59:12
I have an 8400 and I am pretty sure you can switcht between the two. It does sound like a foreign built tractor. Usually foreign tractors have a really wide seat belt to but not always.
