5020 Value
RustyG
11-21-2006 07:42:37
Looking at buying a 5020. It has a Factory cab on it, 3pt all complete. It is missing a few cosmetic things, but it is overall in good shape. The guy is asking 5000 for it. Never priced one or looked into these. Any suggestions?
Glen in TX
11-22-2006 06:17:18
 Re: 5020 Value in reply to RustyG, 11-21-2006 07:42:37
That price is about tops for a good used 5020 although if one has just been thru the shop with a fresh engine or trans repairs you will see dealer asking a lot more to cover what they spent and just breaking even if they can get that. A good 6030 can be bought for 7-10K so why spend more on a older 5020 that may need engine overhaul sooner? The original 531 engine is getting expensive to overhaul and will continue to be that way too because of no aftermarket kits for it. So a rebuilt or salvage 619 becomes a less expensive alternative.
RETIRED 5010
11-21-2006 17:37:17
I have a 1965 5010-IND . - no pan. new batts. -& starter. ser# 8826. in 65 they only made 656 units . this tractor is going to be stored outside this winter because I have to get a 4010 I restored this summer in its place inside for the winter. Please e-mail me back if you are interested in this tractor. I have already ran out of room for storage. thanks.
SD 5020
11-21-2006 10:07:45
Here in SD they bring $3000 for good ones. They just have not caught on as a collector tractor.
PeterE
11-21-2006 10:36:56
 Re: 5020 Value in reply to SD 5020, 11-21-2006 10:07:45
They're kind of big for a collector's tractor. I know there are a few people out there who have 7020s, 8020s, etc. But the average guy can't put a 5020 behind the pickup and haul it to the steam show.
TimS in Mo
11-21-2006 08:57:45
How many hours? What has been done to it (rebuild, clutch, hyd pump, anything) ?
What engine, gas or diesel, what shape are the tires?
On a lot of these older tractors unless it's a collector item you are buying the remaining hours in the engine/transmission and the amount of useful life in the tires....
mjbrown
11-21-2006 13:26:50
 Re: 5020 Value in reply to TimS in Mo, 11-21-2006 08:57:45
They made the 5020 in gas! It's scarey to think what that would burn working hard.
low budget
11-21-2006 16:26:11
 Re: 5020 Value in reply to mjbrown, 11-21-2006 13:26:50
5020 never came in a gas burning version. Mini Mo made some big LPG burners though, I think a 504 cid engine, they also had a 800 cid LPG engine that would bolt right in a G1000. By the way if you have any use for a 5020 and it runs good and has decent tires $5000 doesn't sound like that bad a deal to me (of course $3000 sounds a whole lot better.)
