Help.. Need Work around fix on 4020 D
Nylon
11-20-2006 23:25:02
Northern MN here and coldness approaching fast. I have a circulating heater that just shorted out. Anyone know how many watts the deere heaters are? I will be getting a Katz but want to know if I should go all out at 1500 watts or down to 500. In this cold country bigger is better but didnt want to overdo it. And I cant tell what size the one I have is. I cant get it apart to put new cord on it other wise unit heats fine just old wires that have lost insulators and are arcing.
Now for the tragic / comical part of this. I asked a bone yard about a oil heater. He told me he saw a crankcase oil heater in the parts book but didnt carry anything but bones and didn't have one. I figured between a circulating heater and an oil heater I would have a better shot at an emergency start if needed.
So I called a nearby deere ag dealer and he looked it up....they are available. Yeah! However, there are only 2 left in the world. So Deere has them priced at over $400 plus extra for adaptors and such so that the final price was close to $600 for a oil pan heater. Is that tragic or comical?
Anyway, I need one. There certainly must be an element that will thread directly or via adaptors into the oil pan bolt hole in the front right bottom of the pan where the grand illustrious part was supposed to go. Anyone know how many watts that oil heater should be? And anyone have a good replacement idea?
Thanks,
John
WMA
11-22-2006 13:53:47
 Re: Help.. Need Work around fix on 4020 D in reply to Nylon, 11-20-2006 23:25:02
anybody thought about the weight of oil he's using? sometimes we get hung up on this 30w or 15-40 that pours out of a quart can like molasses at 10 above.makes cranking hard.A friend of mine here in Va. ran deere 10w20 year round in 95 degree weather(plowed w/5 bottoms too)for 20 years and never had any engine problems w/a 4010.
I run 1540 then put a qt of marvel mystery oil in when cold weather gets here,then go back to 1540 in the spring.i only put around 75hrs/yr on my stuff. at least 10w30 could be considered
msb
11-21-2006 20:37:15
Gee, not sure I even want to get into this melee, but I will risk it.On the oil heater question, I would save my money unless you experience extremely,extremely cold weather. Warming the oil is not nearly as beneficial as warming the water.Cold oil is not nearly the problem as is cold pistons and cold ignition especially in a diesel engine and an oil heater will not warm the upper parts of the cylinders where the heat needs to be.I found that out in 1960 with a new 730 Diesel.You will get a lot more bang for your buck with a recirculating tank heater.
We had customers who used 24 hour timers to kick on a couple hours before they fed, but since your need is an ad hoc one then maybe you should go with the largest recirculating tank heater you can buy and rig it to a remote control switch that you could activate from the warmth of your house.An old tarp or an old overcoat covering the engine would help warm the engine a bit quicker even if it sets outside. If your old Deere heater is the aluminum tank kind that mounted just under the generator or alternator then it should have been a 1500 watt unit.Used to be Deere had new elements available.Maybe your dealer could check to see if a NOS part is still availabe somewhere in the U.S (from one of the grumpy old Deere mechanics society-LoL,bob)
msb
11-21-2006 20:47:43
 Re: Help.. Need Work around fix on 4020 D in reply to msb, 11-21-2006 20:37:15
Part numbers: AR 42325 complete kit
AR 42883 element
msb
11-21-2006 20:51:46
 Re: Help.. Need Work around fix on 4020 D in reply to msb, 11-21-2006 20:47:43
Also part number: AR 42326 complete heater without mounting hardware.Good luck,bob(msb)
Glen in TX
11-21-2006 18:17:00
Something we have been using over 7 years now on the block heaters on trucks with good luck are an adjustable sealed thermostat unit and I bolt them on fire wall using rubber isolation grommetts and the heater just plugs in one end of thermostat and cord out other end. Got them at farmtek.com
Gerald J.
11-21-2006 09:16:41
My parts book for pre side console 4020 says they oil heater is AR27139 240 watts. If its 3/4" pipe thread and the picture is true to proportions it must be 6" long, maybe 7.
The next page shows the tank heater and has a part number for the element, AR42883 but it doesn't show the power rating. Looks like the top of the heater unbolts by four bolts. I've not looked at the one mon my gas 4020. Never had to use it either with a good battery. The power rating might be in the shop manual but its not handy to the computer.
Gerald J.
Nylon
11-21-2006 10:58:38
 Re: Help.. Need Work around fix on 4020 D in reply to Gerald J., 11-21-2006 09:16:41
Thanks Gerald,
I dont know the make of the circ heater on it now. It cant be disassembled either which is odd. It looks like a katz but everything is crimped. Was wondering what deere used for wattage on their deere brand probably made by katz heaters.
Gerald J.
11-22-2006 17:59:27
 Re: Help.. Need Work around fix on 4020 D in reply to Nylon, 11-21-2006 10:58:38
I searched the early 4020 (and 4010) shop manual last night. It doesn't seem to admit anything about either heater. The oil heater in the parts book is 240 or 250 watts. There's nothing about the water heater except it has case separate from heating element that can be replaced.
I haven't found my operator's manual since yesterday to see what it says if anything. Its not in the pile where I expected to find it and moving the shop manual caused an avalanche of stuff that took a while to correct.
I was within 20' of my 4020 this afternoon but didn't pause to look for any identification on the heater either for maker or power consumption. Its green, but it may have beeen painted over some time.
Gerald J.
Bob
11-21-2006 07:46:05
I checked the Phillips-Temro catalog this morning, and then priced a couple of the oil heaters at a local auto parts store:
Phillips-Temro Part # 2201968, 3/4" NPT, 11-1/8" long, 300 Watt... $28.39.
Phillips-Temro Part # 8603243, 3/4" NPT, 5-1/2" long, 300 Watt... $68.38.
I don't know how much room there is for element length, but the 5-1/2" unit should fit, for sure.
The longer element would have the advantage of lower Watt density, if there's room for it.
Typically, it is recommended to plug in the oil heater at shutdown, before the oil gets thick, and does not circulate well, possibly burning out the heater, or "coking" it up with charred oil.
Dale in IN
11-21-2006 06:46:10
Go to google and type in kats engine heaters. Then to amazion and you can find all types of engine heaters made by kats. And at prices that are afordable.
I ran into this problem a few years back with a JD 730D. The 730 had an oil pan heater orginally that goes into a pipe plug in the oil pan.
I went to a local farm store that sold kats heaters. All they had was the tank type. So I went through their catalog and kats does make all kinds of engine heaters, However they would not order the one that I needed for they said they would have to order at least one dozen.
R. John Johnson
11-21-2006 05:53:27
Nylon
Don't mess around. get a minimum 1500 watt heater. Thats a lot of metal to heat up.
John
jdemaris
11-21-2006 05:21:36
You can't go too big with a tank heater as long as you have enough electricity to run it. They are thermostat controlled and shut themselves off once the engine gets warm enough. A big heater, if left on long enough, will get your oil warmed up enough for safe starting. We get down to 30 below here in New York - but 20 below is more common. At the Deere dealership, we installed 2000 watt Katz heaters on all the bigger Deere diesels that we sold - unless the place it was going had old wiring. They still only cost around $35. We installed a few diesel-fired block heaters also - mostly for log skidders parked in the woods. The 2000 watt heater needs a 20 amp, 120 VAC outlet. Old circuits often have only 15 amp outets, and also - a 2000 watt heater does not work well with most extension cords. I've got one large dozer that is a hundred feet from a outlet, and I made a 10 gauge extension cord for it.
Bob
11-21-2006 07:40:02
 Re: Help.. Need Work around fix on 4020 D in reply to jdemaris, 11-21-2006 05:21:36
jd,
I have to disagree with your "bigger is always better" circulating heater idea.
YES, if quick warm up is desired, and it won't be left plugged in for days on end, get a BIG heater.
NO, if the tractor will be plugged in for long periods on "standby".
In our area, we have quite a number of cattlemen who leave their Deeres plugged in for long periods, for the duration of the COLD part of winter.
Under this use, several of the guys were replacing 1500 or 2000 Watt heaters every winter or two. We then put on some 750, and 1000 Watt heaters, which have gone for as much as 10 years without failure. It may be the tiny little thermostat inside that fails when a big heater cycles continously for days on end.
I checked the Phillips-Temro catalog this morning, and their recommendation is as follows:
For diesels up to 550 CID, and temps as low as -30, they recommend a 1000 Watt circulating heater.
jdemaris
11-21-2006 08:05:27
 Need some common sense? in reply to Bob, 11-21-2006 07:40:02
What someone else recommends means little to individual situations. That goes with heater-tech guys and especially with some of the Deere engineers I've met. Some were book-trained with no real-world experience and were sometimes less then useless when a problem needed to be solved. Yeah - duh . . . of course having a big heater does not make a lot of sense if it's going to be plugged in all the time. I was assuming that needed not be said - sort of what I call "common sense." If someone here is asking a question and lacks common sense - then there is NO good answer. I guess why I always like the IT series of repair manuals and their frequent comments about certain jobs being "self evident." This guy mentioned cold weather and concerns about getting his engine oil warmed up besides his coolant. A big block heater will do a better job on a 20 below zero morning and high wind - of getting all warmed up. We often installed dual heaters in tractors we sold - a small wattage frost-plug heater and a high-wattage tank heater. Yes, the operator actually had to use some sense about which one he used, how, and when. Imagine that - a choice. Dual heaters work very well. If a guy forgets to plug in, or did but the little heater failed, GFI tripped, or whatever - he have the large tank heater as a backup. I have that setup on my diesel plow trucks. I don't plug in at night unless snow is predicted. If, I wake up some morning with three feet of unpredicted snow - I plug in my large tank heater - and 20 minutes later, I'm fine. So, Bob - you can disagree till the cows come home - but you're not convincing me of anything.
Bob
11-21-2006 08:18:32
 Re: Need some common sense? in reply to jdemaris, 11-21-2006 08:05:27
jd,
It seems to me I WAS using common sense in my first and second posts.
In both, I suggested he size his heater to how he is going to use it.
He did not explain in his post if he wanted quick heat, or if it would be plugged in all winter, so I suggested an option for either scenario.
You simply insist on the BIG heater, without bothering to suggest both options, so he can decide which way he wants to go, based on his usage.
In what way are YOU showing an excess of common sense that gives you the right to belittle my post????
jdemaris
11-21-2006 08:38:03
 Belittled your post? in reply to Bob, 11-21-2006 08:18:32
Bob - not sure what your problem and/or agenda is. You are digitally, and erroneously putting words in my mouth. #1 I did NOT "insist", as you put it, anything. I told the guy he can't go too big with a tank-heater. That comment is correct and was offered as my opinion. #2 You replied directly to my previous comment, telling me you disagree, Okay. And - I, in turn, told you - I equally, disagree with you. Now- you attempt to label my reply as an attempt to "belittle your post." Bob - what a load of crap.
Bob
11-21-2006 01:30:44
The size of the circulating heater depends upon your location, if the tractor is kept inside, or fully exposed to the elements, and if you want quick heating, or plan to plug it in the night before it's needed.
I'm in COLD northern ND, keep the tractor in a pole barn, and try to plan ahead, and plug it in.
My heater is 750 Watts, and the tractor has never failed to start after being plugged in for 6 or 8 hours. Colder climate, or more exposure, or quicker heating, get a 1000 or 1500 Watt unit.
The OEM oil heater was 240 Watts.
It has a 3/4" pipe thread, so any oil heater that has a 3/4" thread, or can be adapted to a 3/4" pipe thread SHOULD work.
Phillips-Temro will certainly have such a heater, at a FRACTION of the price you were quoted.
Their website is linked below.
You can download a catalog, and should be able to locate a reseller in your area.
Jim in AK
11-21-2006 00:09:11
Up here I use a 1000W tank heater and a 300w glue on the out side of the oil pan oil heater. I have started my 4010D in weather as cold as -30�f. But I don't normally start it at or below zero unless I absolutely have to.
Jim
Nylon
11-21-2006 10:55:12
 Re: Help.. Need Work around fix on 4020 D in reply to Jim in AK, 11-21-2006 00:09:11
Great info guys! I should have explained my use a little better. I dont have a regular agenda ie cattle or milking etc. This tractor at the moment sits outside till I get my shed up next year. I use the bucket for snow after I have plowed up banks. I also have a 7 foot international blower on it. So it will on occasion have to be used to blow snow through banks too big to plow through. It happens on occasion...which usually is followed by a big northwest wind and plumetting temps (-15 to -35) after a front passes.
I have pluged in my circulating heater on a day where the temp has risen to -5 for the high after being 37 below. 2 hours after plug in there was no hope in getting it to crank much. Good batteries too on a good starting 68 diesel. This tractor starts at 23 degress with no heat. I needed the tractor because a some nitwit from the south...no insult intended brought a big 18 wheeler in to drop off belongings at the neighbors. He was getting sent to Iraq so she was moving in with parents and military was moving their stuff via contract haulers.
Any way he didn't put chains on and managed to get stuck 3 different times. And had the road blocked for 4 hours. We managed to get a farmall 460 gas started but needed the extra and heavier 4020. Woulda helped tremendously. So these are the types of situations where I need a start. Also I have done some ditch diving in my plow truck and need to pull myself out.
Thanks for the wattage on the oil heater. Anyone know for sure that the plug hole in the right front on a 68 diesel 4020 synchro oil pan is 3/4"?
I will probably go with 1500 watts on the circulate heater. I do have heavy cords and 20 amp circuit. I will be able to plug both heaters into the 20 amp outlet.
John
Nylon
11-21-2006 11:05:13
 Re: Help.. Need Work around fix on 4020 D in reply to Nylon, 11-21-2006 10:55:12
Sorry guys..just reread the posts and it looks like the oil heater is 3/4 threads as mentioned by several guys. Thanks for the links and such. Seems odd that a 5.5 " heater is 40 buck more htan the same heater at 11 inches. I would be tempted to go longer but gerald estimates the scale at shorter than 11. Thanks again!
Nylon
11-21-2006 11:23:12
 Re: Help.. Need Work around fix on 4020 D in reply to Nylon, 11-21-2006 11:05:13
Update!
I called Napa and they have a variety of heaters and show several for deere. However all of their oil heaters are 1000 watts. And he thought they looked to be 5 inches. You Think thats too hot?
