Dubuque steering part
jd420
11-20-2006 18:15:43
On the vertical steering shaft, the two pins that turn in the worm gear. How do you remove them from the steering shaft? Are they riveted in or are there threds? Does any one have yery good used ones for sale? The part # is Am1514T or replaced by Am1515T ?? Thanks for any Info!!!!
Chooch
11-21-2006 06:10:43
 Re: Dubuque steering part in reply to jd420, 11-20-2006 18:15:43
jd420,
Although I do not own any Dubuques, my dad and brother have upwards of 20 or so. I would hate to guess how many of those we have had to work on those pins you asked about. First of all, the pins should be riveted in the arm at the top of the shaft. You should need to grind the rivet off of the top of the arm and drive the pins out the bottom with a punch. New pins are still available from Deere for about $50 each. Upon observing the pin, most of the wear will occur on one side of the pin only. (The only exception is if someone has removed them and rotated them. In this case, the top will probably not be riveted but spot welded.) The reason for the wear is that less than 180 degrees of the pin meshes with the steering gear during travel from a hard right turn to a hard left turn. Therefore, rather than buying new pins, we usually grind the tops off, strike an alignment mark on one side of the top of the pin and arm, drive out the pin, rotate the pin 180 degrees, reinstall (alignment mark will now be 180 degrees out of phase), and spot weld the top of the pin to the arm. We have repaired numerous Dubuques this way with good results. Just my 2 cents.
Chooch
Hayfarmer
11-20-2006 18:55:13
On my 430 they are welded on the top. I had one come loose last year and it wobbled really bad. The parts book list them as a separate part but I rather doubt you could buy them from Deere at least. Generally the steering box comes as a unit, includes the shaft you are talking about along with the worm gear. I think the worm gear gets worn along with stubbs you are referring to and if you change one without the other it takes a while to adjust to each other. When the one on my 430 came loose I re welded it being careful to get it in right. think it may have turned a little as it seems to steer harder now.
