Identify 4020 engine
Polaris96
11-20-2006 12:28:56
I have a 1964 4020 that I believe the engine was swapped at one time. It has a turbo which uses oil filter AR43634. The fuel injector pump is made by bosch. Can someone identify this engine and what models it was used on. The engine serial tag 6404TH-01 354166R. Thanks for any information.
tony from sw ohio
11-20-2006 19:26:50
 Re: Identify 4020 engine in reply to Polaris96, 11-20-2006 12:28:56
what kind of hp power wood it have
msb
11-20-2006 19:15:52
Probably a late 7700 Turbo Hydro combine.
Polaris96
11-20-2006 16:35:59
Yes, the engine tag is upside down so that greatly narrows it down to a combine. Thanks for the much need information everyone provided.
95CS
11-20-2006 15:55:41
Best guess is that the engine is from an early Turbo 7700 Combine. The code can be read like this: 6= number of cylinders. 404 = displacement in cubic inches. T= turbocharged. H= engine was installed in a Harvester Works product. O1 = 1st version. If I recall correctly, the first application by the Harvester Works of a turbocharged engine was the Turbo 7700 Combine in 1973.
jdemaris
11-20-2006 14:51:15
Deere 4020 never had an OEM turbo or a Bosch injection pump. You've probably got a 4230 or a 4320 engine.
New-Gen
11-20-2006 16:06:02
 Re: Identify 4020 engine in reply to jdemaris, 11-20-2006 14:51:15
Deere 4020 never had an OEM turbo or a Bosch injection pump. You"ve probably got a 4230 or a 4320 engine.
Neither did the 4230. And the 4320 never had a Bosch pump either.
jdemaris
11-20-2006 17:42:51
 Re: Identify 4020 engine in reply to New-Gen, 11-20-2006 16:06:02
Well, I should of been more specific. We sold some newer (newer then 4020s) Deere tractors with the 404 engine, Bosch inline pump, turbo/aneroid, etc. My point was, and is, a 4020 did not have the turbo or Bosch inline. Which one did, I don't recall for sure - but it was one of the 4420-4430 or 4620-30 series. Heck, I rebuilt several, but it's been a few years (like well over 30).
New-Gen
11-20-2006 22:33:40
 Re: Identify 4020 engine in reply to jdemaris, 11-20-2006 17:42:51
The 4430 and 4630 had the Bosch inline. 4320/4520/4620 all had Roosa-Master rotary.
4420 was a combine.
(Not tryying to be aynal, just showing off my small store of knowledge)
jdemaris
11-21-2006 05:43:34
 Re: Identify 4020 engine in reply to New-Gen, 11-20-2006 22:33:40
Yeah, I could of looked it up - I have all the data - just lazy. We sold just about every Deere in the industrial, forestry, agricultural, and consumer line since the 1010s were new - up until 1991. I just don't remember all the numbers - especially for the bigger tractors. Back in 60s, in my area of mostly 50 cow dairy farms, a 4020 was considered HUGE. My neighbor bought the first ones in town (he bought a pair). They spent as much time on other farmer's fields, as his own - since they were constantly getting borrowed. We didn't have much demand for anything much bigger - but we did sell a few 404 powered tractors with the Bosch pumps. Some bigger-scale farmers started using large chisel plows - and the 4020 sized tractors will not pull them in our rocky ground.
Mike M
11-20-2006 12:53:52
If the tag is on upside down they were that way on combine engines so you could read it from looking over top of the valve cover. Maybe this will give a clue ?
