Converting to side console
RSCO
11-19-2006 17:40:15
I have an opportunity to buy a 1967 3020 gas for $6,000. It's a nice tractor with low hours, but of course doesn't have a side console, which I'd like to have. I'm assuming that it's not practical to convert an early 3020 to a side console, even with used parts. Am I correct?
shopdoc
11-20-2006 20:15:08
 Re: Converting to side console in reply to RSCO, 11-19-2006 17:40:15
I have a 4010 John Deere that I converted to a side console. Very simple procedure, cheap and it works like a dream. Email me and I'll give you all the details.
Mike M
11-20-2006 12:33:22
I never really had much trouble with the dash mounted controls as long as the adjustments are free on the seat so you can set it where you need it. How much are you planning to use this tractor ? If very much those gassers get mighty thursty ! They are real nice for cold weather and starting and stopping alot. I've had real good luck with our 4020 gas.
low budget
11-20-2006 00:12:22
You can do what Gerald says, but you may find the "on dash" hydraulics are actually pretty easy to operate with your left hand while your turned to the right watching the implement. Also I kinda like the manually engaged PTO with the large lever better than the leak prone hydraulic engaged type.(have one sitting in the shop right now that needs fixing)
Gerald J.
11-19-2006 21:02:13
Once you start comparing early 3020 to late (side console) 3020 by getting both parts books (at least the 4020 parts books and shop manuals are distinctly different) you may wonder if there is anything in common between them other than tires, seat, number decal, and paint. Probably some bolts and nuts.
Its conveivable you could get the side console function, but it wouldn't make it a Deere side console. The 3 point is controlled by a valve down on the right side of the rear end through a push pull cable, that could be rerouted with a push pull cable or some linkage to a handle hung on the right fender.
You can tap the hydraulic system (full pressure and flow at the elbow just in front of the brake pedals) and put in a flow restrictor valve (a 3 x 8 cylinder gets from one end to the other in 5 seconds if you flow 5 gpm and without the flow restrictor you could flow 20 gpm which gets a pain to control) and hang a closed center hydraulic valve on the right fender. I'd hang it under an elbow shelf with the fittings down and reverse the handles to reach above the shelf. Then I'd plumb it to some dual connect under pressure pioneer assemblies out back. The return goes to the transmission oil filter cover, either drill and tap yours or get the one made for a 2640 and a loader by Deere. You could mount a 3 circuit valve there and with the one or two on the dash you could have 4 or 5 remotes, better than any side console which couldn't have more than three.
Gerald J.
msb
11-19-2006 19:31:01
You are correct.Myself,I prefer the older style operator's station.Never did like sitting and banging my knee on that thing all day.Not my idea of fun. Its almost like it has a knee magnent in it.lol,bob
