70 Diesel Fuel Guage
WyoDave
11-19-2006 16:15:47
My grandfather had a 70D that he converted to electric (24-volt) start with pieces from a 720. The tractor is now mine, and at first I had planned on putting the starting motor back on (I got it and all the pieces he removed with the tractor). Now I've decided to keep it electric start in memory of my grandpa. I've been working on the wiring, and I got everything hooked up and working except the fuel guage. It has the original 6-volt guage and sender. It works on 6 volts because I tested it that way, so I'm wondering whats the best way to convert it to 12? Can I use the existing sender and guage, or will I need parts off a 720 Diesel to make it happen.
David
Scott Griffith
11-20-2006 05:43:59
 Re: 70 Diesel Fuel Guage in reply to WyoDave, 11-19-2006 16:15:47
If you need a 12 volt fuel guage then try this company. I found a distributor and installed one on my 720 of which I converted to 12 volt. It is inexpensive (both the guage and sender), easy to install, and looks similar to the original.
Scott
WeirdDeere
11-19-2006 20:56:30
You may want to just find a 12 volt fuel gauge and sending unit. If you are running a 12 volt system, you'll likely have negative ground. I've learned from experience that the original sending unit/gauge DOES NOT like it when you switch from positive to negative ground. I accidentally hooked mine up backwards and fried the sender. And this was with six volts!
I'd pack away your working gauge and sender and save it. They are expensive to fix or replace.
Brandon
My Industrial John Deere website
John Deere Diesels
The LaGrange Engine Club
Scott Griffith
11-19-2006 17:37:54
If you know how to wire in a voltage regulator, you could drop the voltage down to 6 volts. I believe a 7806 will do the job. I have used these regulators in the past and they are good for up to 1 amp. If you have questions on how to hook it up then send me an email and I'll help the best I can. I don't know if you can get them at Radio Shack. I have bought them in the past from Digikey for about 50 cents in the past.
Scott
