JD - A - help
cam2
11-19-2006 13:54:52
need some help with carb setings on jd a
Mike M
11-19-2006 15:06:06
 Re: JD - A - help in reply to cam2, 11-19-2006 13:54:52
These are just "starting points" final adjustments are needed. Idle needle ( one closest to you standing on the LH side )1 1/2-1 3/4 load needle 3/4-1 turn backed of after lightly seating them.
cam2
11-19-2006 16:45:46
 Re: JD - A - help in reply to Mike M, 11-19-2006 15:06:06
thanks mike
Mike M
11-19-2006 18:18:56
 Re: JD - A - help in reply to cam2, 11-19-2006 16:45:46
Once in a great while you will find one that the idle needle will end up out alot farther to make it run right. But those settings above should get it running.
