FIT - Painting a New Radiator Core
Jason Z in MO
11-19-2006 09:14:05
Frank / all,
Looking back in the archives I read your posts from 2002 when you asked about painting the radiator core on your 70. I understand you painted it green. Some people prefer black, some green and some leave natural. Wondering what process you are using today?
The new core I'm using for my B came from A&I and is 100% copper. Looks nice with the copper color, so I thought about clear coating it but once it's all together whose gonna see it!??!?
Realizing the old core had much larger tubes than the new I was concerned about flow capacity. I also notice the very ends of each tube, just above where it�s soldered to the plate, were slightly crimped. Using a screw driver I gently opened the ends of each tube being careful not to disturb the solder joint. I'm sure this will increase the capacity. Has anyone else tried this?
Jason
Mike M
11-19-2006 15:11:21
 Re: FIT - Painting a New Radiator Core in reply to Jason Z in MO, 11-19-2006 09:14:05
Painting them is not a good idea as it insulates them from thermal transfer. If you absolutely must paint it then get some of the paint special made for radiators. I don't know what makes it special but it is advertised just for radiators.
F-I-T
11-19-2006 15:26:00
 Re: FIT - Painting a New Radiator Core in reply to Mike M, 11-19-2006 15:11:21
Wives tale, Mike. Calculate the R factor of .002 of enamel sometime. It's far less than a layer of dust.
Mike M
11-19-2006 18:34:21
 Re: FIT - Painting a New Radiator Core in reply to F-I-T, 11-19-2006 15:26:00
Not so sure about the wives tale ? Could be ? But I'm sure I read this in some of the service information somewhere.
It never became an issue with me as I paint everything seperately then assemble it. Nothing wrong with the look of copper fins to me. I'm sure the factory put everything together then squirted paint on everything they could easily reach and I'm sure that core got some on it.
While were on the subject I just remembered there is a right way and a wrong way to install those cores in relation to up and down. The service manuals show this. The cores are built with a curve to them ( and you want to install them so the high spot of the curve is on top so water and dirt won't lay in them.
Jason Z in MO
11-19-2006 20:11:18
 Re: FIT - Painting a New Radiator Core in reply to Mike M, 11-19-2006 18:34:21
Mike,
With regard to the correct "up" on the core, I read that too but the fins on the replacement were not like the factory core. Ended up mounting it with brass name plate on the core right side up.
Btw, still haven't resolved the problem with the 4020 injection pump...
Jason
F-I-T
11-19-2006 09:51:26
The factory painted them green, so I still paint them green, but not a heavy coat. I spray from above and below so the paint lands on the edge of the fin and not fill the rectangle where the air needs to go through. Not sure clear would stick very well unless the copper and brass was really, really chemically clean.
I also always "rod" out the ends on a fresh cores as a few pipes are always bent, partially solder filled, etc.
Frank
Jason Z in MO
11-19-2006 17:14:27
 Re: FIT - Painting a New Radiator Core in reply to F-I-T, 11-19-2006 09:51:26
Frank,
Thank you for your comments and I appreciate your experience. Without expecting anything in return, you provide very well thought out and thorough responses!
The above comment was not to take away from anyone else's advice on this board, always welcome and appreciated!!! I feel like I pick on Frank all the time!
With regards to radiators, I realize there are several options and there is probably an equal percentage of folks who use each option. Each with its own merits.
Jason
P Browning
11-19-2006 15:37:45
I doubt radiator cores were painted at the factory -- except perhaps some overspray. We had JD tractors from a 36 JD-A on and not one had a painted core. 'Best to just leave it natural. (PatB)
F-I-T
11-19-2006 15:57:01
 Re: FIT - Painting a New Radiator Core in reply to P Browning, 11-19-2006 15:37:45
Your opinion, but I've been around a few originals in my time, too. The original two cylinder tractors I have removed cores from include two cylinders like unstyled A's and B's, 70D, 70G, '48 and 49 'A's, several 60's, 2- H's, and a half dozen "B"s had significant "overspray" on the fins, so I decided to do the same. The rest had already seen paint by the time I got to them. By the time the 4020's came along, the oil radiator and the coolant radiator were painted, most too heavily in my opinion. 45 "roundback" Combines had the cores painted, as well as LUC's.
If they weren't painted at the factory, how did they get that green stuff on the tanks, top and bottom, hold down straps, nuts and bolts, as well as the area on the tops that was under the hood? Some even had nice paint inside the shrouds. Those models with power steering like 50/60/70 even had the rubber sheathed hydraulic hose painted that was entirely under the hood and grille, so some paint was applied before the sheet metal went on.
BTW, look at an original "D" or GP with frontally exposed radiator fins, or an unstyled A/B/G sometime. There's green paint all over the front of an original. Even after they went to models that had front grille covers, those radiator assemblies nust have had some pre-painting, because the assembly rack photos from those days in the factory show that. Two Cylinder magazine over the years has posted many painting room and assembly photos at Waterloo photos that show all of that pretty clearly.
I didn't say paint heavy and throughly, but he asked me and I told him what I do.
Frank
P Browning
11-19-2006 16:18:22
 Re: FIT - Painting a New Radiator Core in reply to F-I-T, 11-19-2006 15:57:01
You make my case! It wasn't by design that cores were painted. They were in the way of flying paint! Jason Z has a choice. He might be very wise to choose not to paint the core -- that's the entire point of the thread!!! (PatB)
F-I-T
11-19-2006 16:23:17
 Re: FIT - Painting a New Radiator Core in reply to P Browning, 11-19-2006 16:18:22
I said I mist a coat ontop mine. The factory overpsrayed the cores. Your statement that they were not painted at the factory is not accurate. Whether they meant to or not, they were painted, even if by collateral activity.
Jason does indeed have a choice. In this thread he chose to ask me.
P Browning
11-19-2006 17:44:28
 Re: FIT - Painting a New Radiator Core in reply to F-I-T, 11-19-2006 16:23:17
He may have asked you but I rather imagine he will appreciate having heard the whole story! Good Night Frank. (PatB)
F-I-T
11-19-2006 18:10:39
 Re: FIT - Painting a New Radiator Core in reply to P Browning, 11-19-2006 17:44:28
Pat,
You might be offering stories, but I based my response on my observations during the examination of many original tractors and numberous photographs.
If you were guessing, say so. But, he asked me how I did it and I told him. Your continued aversion to empirical evidence may indicate a need for therapy on your part. Good luck with that.
P Browning
11-19-2006 17:44:19
B-maniac
11-19-2006 17:05:00
Got-ta-love it! For once, I'm not in the middle of it. I love a spirited discussion though!
JDK
11-20-2006 05:48:18
 Re: FIT - Painting a New Radiator Core in reply to B-maniac, 11-19-2006 17:05:00
I agree... Gotta Love It! But there is one thing missing. Jason, what are you going to do?
B-maniac
11-21-2006 13:53:47
 Re: FIT - Painting a New Radiator Core in reply to JDK, 11-20-2006 05:48:18
First of all,who is Jason?? And what do ya mean "what am I gonna do?? You lost me?
omar
11-23-2006 09:42:12
 Re: FIT - Painting a New Radiator Core in reply to B-maniac, 11-21-2006 13:53:47
You do not paint a radeator with paint! There is a special paint that is black & is mixed with gas
as a thinner ask a radeator man.
