Bleeding the fuel line on a JD2150
Dan Brouillette
11-19-2006 04:52:29
In a time crunch today; can anybody walk me thru the process of bleeding air from the fuel line on a 2150?? Any help would be greatly appreciated! Thanks in advance,
Dan
Mike M
11-19-2006 07:36:11
 Re: Bleeding the fuel line on a JD2150 in reply to Dan Brouillette, 11-19-2006 04:52:29
Did you open up the bleeder screw on the filter housing ? and then use the hand priming lever on the bottom of the fuel transfer pump to pump until fuel came out ? Be sure to push the lever back towards the block when done,if left out it will not pump right. Bleed at the filter then at the inj. pump it should have a bleed screw,and then if it still won't go bleed at the injectors as mentioned below. Do you have the valve open at the bottom of the tank ???
Dan Brouillette
11-19-2006 08:35:48
 Re: Bleeding the fuel line on a JD2150 in reply to Mike M, 11-19-2006 07:36:11
Mike:
The tractor is new to me...I found the bleed screw on the filter. That worked to get it running. The lever you mentioned under the fuel pump won't stay in the position closest to block; don't know why. The valve under the tank is closed. Engine ran fine for about 5 min; when I attempted to move it, I could see the fuel level in the filter get lower, then the engine dies. If I start the process over, same result. Time for a new fuel pump? Or any other ideas? Thanks again for the help. You guys are great.
Dan
Mike M
11-19-2006 15:17:24
 Re: Bleeding the fuel line on a JD2150 in reply to Dan Brouillette, 11-19-2006 08:35:48
You said the valve under the tank is closed ?? Then this is the problem make sure it is open (counterclockwise)
I'm talking about the shut off valve,some also have a drain valve like a radiator petcock. If you have one of these open it some and drain off some of what's in the bottom of the tank.
brianriver
11-19-2006 05:48:55
Not very familar with this model but have had pretty good luck with cracking one or two injector lines at the injectors and cranking engine until fuel comes out. Have someone help you if you are in a crunch. Once the engine coughs a little, close all but one injector line until it runs for a few seconds, then close the last line. This may not be the factory procedure, but it can work. You can take degreaser or high pressure water to remove spilled fuel and reduce the possibility for dust build up and future hot spots or fires. Be safe, keep hands away from fuel line, may wish to wear leather gloves when cracking or tightening lines.
Dan Brouillette
11-19-2006 06:51:37
 Re: Bleeding the fuel line on a JD2150 in reply to brianriver, 11-19-2006 05:48:55
Thanks Brian. Cracked a line and turned it over until the air bubbles stopped. Engine still won't start however. Looking for next steps now. Engine ran until I changed the fuel filter, now won't start. I thought it was air in the line, but may be something else. Any thoughts/ideas greatly appreciated!
