4 bottom pull type plow
toolz
11-18-2006 18:35:09
Probably should ask this on the implement section, but I thought this group may know more about it. Just bought a JD 4-16s trailer plow with hydraulics and a big beam. Don't know the model number. It has a small (12") rear wheel that is adjusted all the way up. What would be a good starting point for this adjustment? The plow sits low in the rear when all the way up, and the rear wheel is off the ground about 5" when lowered. I don't think I'll have a chance to try it out this fall. Also, please let me know the model number if possible. Thanks
toolz
11-19-2006 21:40:05
 Re: 4 bottom pull type plow in reply to toolz, 11-18-2006 18:35:09
Thanks, guys. I'll try that next weekend. I sure would like to get it in the ground yet this year.
msb
11-19-2006 11:26:16
Probably a model 620 or 630.You can do a reasonably good job of adjusting a plow on a concrete floor.With the plow lowered,block up the land wheel at the depth you want to plow.Then set the furrow wheel level with the front share with the front of the frame level.Set the tail wheel where there is about 1/2" clearance under the rear share.The tail wheel should lightly mark the furrow bottom when in the field and angled a bit so it absorbs the side draft on the bottoms to keep the plow running straight.
F-I-T
11-18-2006 19:10:24
I would start at setting the tail wheel about 3/4" lower than the rear share. Some folks set them at flush, but then the tail wheel doesn't support the weight of the rea of the plow as it is intended. Either way should get you very close.
To fine tune, you can put a 6x6 under the land wheel, and every thing else should be trimmed to be level when sitting on the ground. Frank
