1946 Model B Starter Questions
Gimpl
11-18-2006 17:25:13
I just bought this B and the starter was off of it so I had to pull it to get it starter. The generator has been taken off and replaced with an alternator. I put the starter back on and tried starting with a 6 volt battery and it did not even turn when I touched the cable to the copper nubon on the side of the starter.
I am wondering how much it would cost to have the starter rebuilt.
My other thought is that it has been converted to 12 volts but not sure how to tell. Any one know how to figure out 6 vs 12 since it did not have a battery in it???
Derbynut
12-02-2006 22:18:55
 Re: 1946 Model B Starter Questions in reply to Gimpl, 11-18-2006 17:25:13
It"s most likely nothing to do with voltage rather a starter issue providing you do know you have a charged battery and good connections. As mentioned if it has an alternator it IS 12 volt and also as mentioned there is no need to convert a 6 volt starter to 12 volt. I"ve converted countless tractors to 12 volt and there has never been an issue in fact it"s a plus as 12 volts sends the starter flying! Of course as with any starter of any voltage on any vehicle (including your Sunday car) never stay on the starter for long periods as it can heat up and burn up a starter or the cables.
Derbynut
12-02-2006 22:18:11
Derbynut
12-02-2006 22:17:22
John T
11-19-2006 08:23:17
Gimpl, I agree with JS, if it has an alternator its probably a 12 volt Negative grounded system now and an existing 6 volt starter ought to spin very fast at 12 volts but still function at normal speed if 6 volts were applied IFFFFF FF the starter is okay????? ???
YES a good old fashioned starter n genny shop can convert the starter over to 12 volts if needed buttttt tttt I always just kept the 6 volt starter when I converted to 12 volts n they worked okay.
Be sure and dont connect the battery at Pos ground if that alternator (which mosty likely is) is for negative ground.
Before you "fix" the starter make sure the battery is good n well charged (or try a known good substitute battery) n alllll lll cables n grounds n connections are good. I would remove, clean n wire brush, n reattach each n every battery n starter n ground connection FIRST. It may be hard to get a good connection by jumping up against the starter post, I would replace a good starter switch n try it that way before I tore into the starter.
John T
Gimpl
11-19-2006 19:01:06
 Re: 1946 Model B Starter Questions in reply to John T, 11-19-2006 08:23:17
Thanks John T. I can pull the tractor and get it started, could I put a volt meter on the alternator and figure out if it is 6 or 12 volts. Also could I check pos or neg ground as well?
I have a 56 420 but this B is all new to me..
Thanks Gimpl
J Schwiebert
11-18-2006 18:02:03
First of all if it has an alternator it is 12 volts. If it is a Delco which most conversions on tractors are it will be stamped 12N plus the model number. Why don't you check. All John Deere tractors like yours when equipped with a generator were positive ground. So the wires on the ammeter may or may not have been reversed so it will read correctly. Your starter will hanle 12 volts just fine. Have you taken just the starter while it is off the tractor and tried to run it with a good set of jumper cables and a 12 volt battery. Used to drive a 46 B that my uncle had, my exposure to a John Deere with starter and lights. J.
