50 Intake manifold
Buck D.
11-18-2006 17:04:32
I have a 1955 model 50 gas.The intake needs to be replaced.My question is...If I can remove the bolts without breaking them, can I just slide it out and leave the exhaust manifold in place? Is it possible to buy just the intake?
MikeinKy
11-18-2006 17:15:31
 Re: 50 Intake manifold in reply to Buck D., 11-18-2006 17:04:32
I think the answer to all of your questions is yes. I have changed several 50 manifolds. I haven't tried to change only the intake. All of the bolts usually come out fine except for the ones closest to the outside edge of the head, which ,I think are the exhaust manifold. I use some heat from a acetelene torch and heat the head enough to get those bolts to turn. I haven't broken one yet. The larger tractors, 60, 70, 620, are another story. I usually end up with the head off on those. I may have a good intake for a 50. Usually the exhaust is the one that is bad, and I replace both together.
Buck D.
11-20-2006 16:23:48
 Re: 50 Intake manifold in reply to MikeinKy, 11-18-2006 17:15:31
Thanks Mike.I guess I'll carefully try the exhaust manifold also.
