6 volt batteries
txasylum
11-18-2006 10:46:56
JD 70 with two 6 volt batteries. Are they in series or parallel? Can I swap out the two 6 volt batteries and put a 12 volt battery in its place without changing anything else? Simply, is the tractor already a 12 volt system?
What size and cranking power should I buy in a 12 volt battery?
Thanks
Bob
John T
11-18-2006 12:05:07
 Re: 6 volt batteries in reply to txasylum, 11-18-2006 10:46:56
Bob, Yep assuming its a gas tractor???? it has the 2 existing 6 volt batterys wired in series so its actually a 12 volt system and was originally Positive ground. Yes, you can replace it with a single 12 volt battery and assuming it's still the original Positive ground be sure n hook it up that way i.e + post to frame ground and - down to startrer.
If it were mine Id use a good heavy duty truck n tractor (they are better rated for vibration) battery rated at least 750 but preferably a 1000 or 1050 or even more CCA battery. While a light wimpy 500 or 600 CCA batery would start it in summer it may well not in extreme cold temperatures. Bigger n heavier n higher rated is what I would recommend to start a 70 gas at cold temps fer sure.
John T
55 50
11-18-2006 12:02:27
The batteries are in series and the system is 12 volts so you can swap in just one 12 volt battery and all will be well. I'm not sure of what size battery you may need, but I have seen others here recommend the biggest physical size you can get into the battery box.
txasylum
11-21-2006 06:56:01
 Re: 6 volt batteries in reply to 55 50, 11-18-2006 12:02:27
Thanks for your reply
