Hydraulics on a 49 JD M
Paul Smith
11-18-2006 05:34:46
My 49 M has hydraulics on it. I'm trying to run a three point JD log splitter off of it. Can some one point me in the right direction for my pressure and return lines. Pictures would help if possible.
Paul Smith
11-18-2006 17:53:42
 Re: Hydraulics on a 49 JD M in reply to Paul Smith, 11-18-2006 05:34:46
Thanks for the replies. Would a 8n have better hydraulics? I have one of them also.
tstex
11-19-2006 05:09:57
 Re: Hydraulics on a 49 JD M in reply to Paul Smith, 11-18-2006 17:53:42
Paul,
I am not an Ford Expert, but most tractors of this vintage era and similar HP/PTO & PSI Hydraulics are of the same caliber.
Here are some other suggestions based on you wanting to do some periodical log-splitting:
* Outsource the log-splitting
* Borrow a neighbors tractor [if you already have the log splitter] and return their tractor filled with diesel or trade-off with something they can use of yours
* Invest in a log-splitter that is self-contained, if not too expensive.
The last alternative is to buy a [used] tractor that can effectively run the l-splitter.
Good luck,
tstex
95CS
11-18-2006 15:41:47
The hydraulic system on "M" series tractors doesn't have enough system pressure or flow to run a log splitter. You'd be better off with a PTO-driven pump, a reservoir, and a control valve.
Brendon
11-18-2006 16:49:39
 Re: Hydraulics on a 49 JD M in reply to 95CS, 11-18-2006 15:41:47
According to my service manual, the M has an operating pressure of just 750 psi, or about a third of what a more modern tractor has. I would agree with you that this would be marginal for running a splitter. I run a splitter from the remotes of a modern tractor with 2000+ psi and still run short of force sometimes in tough wood. The volume of the M hydraulic system is also quite low. If the cylinder has a large rod diameter (making for less oil being returned to the tractor on the extend stroke), there could be problems here too.
tstex
11-18-2006 09:38:29
Paul,
I have a 51 JB MT, which has a bit different hydraulics from yours. I was informed on this forum or another that our hydraulics would be pushing-it to effectively run a log-splitter, unless you just wanted to split old pine or another real soft wood.
If i am wrong, someone please re-post and let us know. I have seen much bigger modern day tractors strain to run a logger splitter where they were trying to split some aged oak.
Good luck,
tstex
