750 compact
RMO/MN
11-17-2006 20:28:54
I'm looking at a 750 a couple of questions. Do these tractors have live PTO and I'm assuming they have down pressure on the loader.
Thanks in advance Bob
Mike M
11-18-2006 05:03:47
 Re: 750 compact in reply to RMO/MN, 11-17-2006 20:28:54
That JD 750 was not live pto on the rear,but they did however have a built in over-running clutch so you won't need to add one. A belly mower and snowblower were ran off the front pto attactment that is live and with an electric clutch.
If you have a JD loader made for that model it will have down pressure and a hyd. bucket. But anyone could of added anything ? Try it out first anyhow.
These are very well made tractors and usually make more HP than rated. I think ? ours was something like 24-25 on the pto. I think ? they were only rated at around 18 ?
RMO/MN
11-18-2006 06:02:55
 Re: 750 compact in reply to Mike M, 11-18-2006 05:03:47
Thanks for the info Mike. Can you tell me are these tractors unstable on side hills and the mower is not on the tractor where could I check to make sure its the right one
Thanks Bob
Mike M
11-18-2006 20:11:34
 Re: 750 compact in reply to RMO/MN, 11-18-2006 06:02:55
As far as being stable on hills ?? They are as stable as any other tractor of that size and width. They are kinda narrow so you gota watch them. I have mowed some pretty steep sidehills with ours. Do you mean loader not mower on tractor ? either way it may still have it's serial number plate on it. Mowers are a 160 and loaders are maybe a 67 ? they may of had others that fit too.
