Jason -- You have asked an excellent question. I address this issue in my book, JD-H Restoration Guide, 2nd Edition. Here is what you will find on page 112. (PatB) INSTALLING THE CORK PACKING (H199R) INTO STEERING PEDESTAL -- See PC304, page 31, for the cork packing (23), then shims (22), and then followed by the eccentric bushing (21), sector gear (40), washer (41) nut (42) and cotter pin (43). The milled area, in the pedestal casting, down into which the cork packing goes is less deep than the cork packing; this being the way of providing a seal. TIP: The approach is to perform the spindle shaft end-play shim adjustment WITHOUT the cork packing to determine how many shims are needed. Then remove sector gear, bushing and shims, and install the new cork packing (presoaked in oil) into the designated region. The packing is then compressed into place beneath the eccentric bushing using a predetermined quantity of shims (the quantity a result of the spindle end-play adjust procedure), the sector gear, washer, nut and (once nut is tightened) the cotter key. ++++
