2150: Need Help
Dan Brouillette
11-17-2006 16:58:37
New to this; have a 2150 that runs great for about 10-15 mins then begins to stutter and gradually die like it's running out of fuel (it's not out of fuel). It won't restart immediately, but after about 10 min it will usually start up again and then do the same thing. Not sure where to start with this one. Any help would be greatly appreciated. Thanks in advance,
Dan
Dan Brouillette
11-18-2006 16:40:29
 Re: 2150: Need Help in reply to Dan Brouillette, 11-17-2006 16:58:37
Thanks for the suggestions; picked up a filter today. One more crazy question: how do you bleed the air out of the fuel system on this machine? If anybody can walk me thru this, I'd be deeply indebted. You guys are the best,
Dan
Tx Jim
11-19-2006 04:03:42
 Re: 2150: Need Help in reply to Dan Brouillette, 11-18-2006 16:40:29
If your just changing filter, after installation open bleed screw at top/front of filter base then pump handle on lift pump until fuel/no air comes out. If no resistence is felt while pumping lever,bump engine over a little to rotate camshaft. Tx Jim
Tx Jim
11-18-2006 03:26:57
As previosly stated change fuel filter,check fuel flow from tank and check fuel return line and pump fitting for blockage. Tx Jim
Dan Brouillette
11-18-2006 13:57:03
 Re: 2150: Need Help in reply to Tx Jim, 11-18-2006 03:26:57
Thanks for the suggestions. Picked up new filter today. Another simple question: I assume after I remove the old filter and install the new one I'll have to bleed the fuel system to get the air out. Can anybody walk me thru this process? Thanks again; you guys are the best.
Dan
Bguy
11-17-2006 18:59:34
I had a 2150 for 16+ years and it was a good tractor. Based on what you are saying I would guess that the fuel filter is clogged. If the filter is clean then I would suspect the fuel pump is going out.
